bradavon78
Not sure if this is best in the AV Receiver or Music Streaming channel. I see people posting in both.
Yamaha RX-V4A Receiver
Background:
I've got Amazon Music Unlimited.
Using the Yamaha MusicCast app you can stream up to Ultra HD Bit/Sample Rate up to 24-Bit/192Khz an this is shown in the MusicCast app.
This works great but like all these Receiver apps, the bespoke Amazon Music user interface in the MusicCast app is poor. I'd prefer to use the Amazon Music app.
In the Amazon Music app, using a Chromecast I can cast Amazon Music HD in 16-Bit/44.1Khz and this is shown in the app.
Chromecast doesn't really support higher than 24-Bit/48Khz though. Chromecast Audio supports 24-Bit/96Khz FLAC files but oddly this is still resampled from Amazon Music. Qobuzz recommend using Chromecast for their 24-Bit/192Khz but it's a grey area whether you get this, much more likely it gets resampled.
I understand with Wiim Mini/Pro you can use the Amazon Music app and using Alexa Cast can playback up to 24-Bit/192Khz.
The Yamaha RX-V4A also supports Alexa Cast and in principle is doing the same as the Wiim Mini/Pro. When using Chromecast the Amazon Music app shows you it's casting in HD 16-Bit/44.1Khz.
But annoyingly when using Alexa Cast in the Amazon Music app the audio quality badge disappears, the MusicCast app stops showing the audio quality and just says "Digital" and the on-screen TV info only says "Digital".
Question:
Given MusicCast and Wiim are doing the same (similar?). Is Alex Cast to the Yamaha RX-V4A also streaming in up to 24-Bit/192Khz or is it as I suspect being resampled to 24-Bit/48Khz?
I can tell the different between Lossy 16-Bit/44.1Khz, Lossless CD Quality 16-Bit/44.1Khz and High Resolution Lossless 24-Bit/192Khz but the difference can often be subtle (sometimes not always). There's a difference though.
It would be initiating to spent £150 on a Wiim Pro (would need coaxial) if my Yamaha Receiver is already casting using Alexa Cast in 24-Bit/192Khz.
Thanks.
Background:
Question:
Thanks.
