stegalv
- Joined
- Dec 16, 2003
- Messages
- 1,059
- Reaction score
- 53
- Points
- 344
- Age
- 68
had the svs pb200 for a few years now,noticed it wasn't working,anyway it's the lfe female plug on the amp has broken apart,tried but can't get it to work,i have taken the amp out of the sub case and the connectors for the controls and cable connectors are on a separate board glued to the amp circuit board.i have managed to separate them,anyone know if i can buy board with the controls from anywhere.or the small unit with the just the speaker cable inputs,be a pig to get off though,
i have an older dayton 450w amp plate from a sub i built before this pb one,could i just replace the 500w pb one with the dayton one.i would have to cut the hole a little bit larger and the only difference i can see is the svs amp has 2 separate double cables from the amp connected together at the speaker terminals the dayton just has the 2 single cables.any help appreciated,
