yep123
Dear forum members, my current TV, a Samsung Qled 4k QE50Q67T, unfortunately broke down. Therefore, I need a new 50-inch TV. I use the TV for watching movies and series in 4k (Netflix, Plex), regular TV viewing, and watching football. No gaming is done on the TV.
The following devices are connected to my TV: NVIDIA Shield, a set-top box (Ziggo), and a Denon 2400H Receiver. All apps, such as Netflix and Plex, are viewed through the NVIDIA Shield. I do not use the TV's sound; I have the Denon Receiver for that purpose.
My budget is 900 euros. I am torn between the LG Oled48A26LA and the Samsung Neo Qled 4K 50QN93B. I slightly prefer the LG, mainly because it is cheaper than the Samsung and supports Dolby Vision. However, I hesitate because I have a bright room, and I have read that an OLED TV may not be ideal for this. The Samsung is a bit more expensive, and another drawback is that it does not support Dolby Vision.
The sun rotates during the morning from the side where the TV is. The sun shines directly into the room where the sofa is located. I would prefer the LG OLED TV. Would that be advisable in my current situation?
Thank you in advance for the feedback.
