Mr X
- Joined
- Aug 8, 2006
- Messages
- 11,159
- Reaction score
- 8,247
- Points
- 3,200
Wow that’s interesting. Would you be prepared to comment on how similar or how different they might be - i’m assuming you probably using some for LCR and some for surrounds so hard to contrast, I suspect . Its certainly easier to find commentary / thoughts/ reviews on the freestanding versions then on the walls and I’m wondering whether what’s said of the boxed speakers can be assumed of the in-walls.
My LCR are actually S5monitors. Part of the reason was I needed a baffle wall at the font to accommodate the subs which are pretty big. They have confirmed inwall and onwall subs are coming so that may be of interest to you.
Then at the sides for my front wides and surrounds I couldn’t go into the walls plus I wanted to angle them toward MLP.
But behind the seats not only could I accommodate them but needed them as we use that walkway and S4s would have blocked access.
So I don’t think I can really comment on a true in wall Perlisten experience as mine are only used for rears.
That said, I’m really pleased with them but I think there was a Matthew Poes or Audioholics video and the verdict was extremely good in both measurements and performance. The Perlisten engineering is very good in general and the fact they use back boxes in wall makes a big difference.
Wish me luck, I’m off to break the news to my wife, that we can’t squeeze her in the cinema on your advice.
There are four of us, and I can’t fit five seats in a row if I wanna go Valencia. I could fit in four, but then there’s no sweet spot. So I figured I’d go with with the first row of 3 in prime position and then a second row on a riser, which will just have to accept, whatever audio comes its way. In a sense then I’ve answered my own question as I guess it matters less if the Perlistens only address the front row properly vertically.
I had to drop from 5 to 4 seats but all I did was position 3 centrally giving me an MLP and one slightly off. Works really well and some people don’t notice till I point it out, but I think thats more to do with my room layout.
You can see the seats and in walls here on my thread if it helps
The Perlisten THX Dominus Den
Well after 10 years of enjoying my first attempt, the time has finally come for me to attempt my "endgame" Home Cinema - if that's ever possible(!) but I am going to get a close as I can to it. Little bit nervous at ripping the room up especially after getting so much enjoyment from it for a...
www.avforums.com
I work in London and live in Hertfordshire these days - so if anyone knows of demonstration facilities in either of those vicinities, do let me know - else I’m not a verse to travelling for the cause
As I said it won’t be much of an inwall experience but I’m about 20 mins from Herts and London in North Essex if you wanted a listen but they are S series.
I’m not aware of any show rooms in the south with Karma and Yorkshire AV being the only ones I know that have them in their demo rooms.
