Zoomplayer/Dscaler audio
Discussion in 'Desktop & Laptop Computers Forum' started by denniswaugh, Sep 21, 2005.
  1. denniswaugh
    denniswaugh
    Nov 13, 2003
    222
    Northampton
    +4
    I've started to use Zoomplayer 4.5 with the Dscaler 5.006 codecs.
    Is there any point to using other audio codecs i.e. Windvd/PowerDvd audio codecs instead of the Dscaler audio codec. I always select SPDIF out to my Yam A1 receiver.
  2. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,488
    South Derbyshire
    +198
    Yes - there is a point. Using Zoomplayer I compared PowerDVD to WinDVD and NvDVD. The Nvidia audio I found ro be the best.
    The codec still handles the SPdif data and they do this in different ways - hence they are not all equal.
  3. mattwakeman
    mattwakeman
    Sep 27, 2003
    108
    16
    Another vote for NVidia but since zoom is so easy to configure just vote with your ears. But I was surprised that moving to HTPC would be a bigger difference to the sound than to the picture.
  4. Dr_Mike
    Dr_Mike
    Mar 10, 2004
    379
    Loughborough
    +16
    I couldn't get the latest PowerDVD(6) audio codec to work with zoomplayer. I get a 'no common media type error' for the connection between the codec and the audio renderer (whichever renderer I use).
    WinDVD works Ok with Zoomplayer but I don't get the full range of audio options (eg Dolby Headphone) that you can see in the WinDVD player.
    With the Nvidia codec, only SPDIF output works in Zoomplayer, all the other options give silence. Everything works fine in WMP though.
    Another one to try would be AC3filter (free). This does passthrough of DD over SPDIF, but doesn't seem to recognise DTS.
  5. denniswaugh
    denniswaugh
    Nov 13, 2003
    222
    Northampton
    +4
    Thanks for the replies.
    I have used WinDVD 6, PowerDVD 5 and Nero audio codecs. Could not get Nvidia to work.
    WinDVD always reverted to 2 channel mode. PowerDVD and Nero didn't sound that good to me.
    Now using the ffdshow audio codec and it sounds good.
    I'm suprised this codec is not mentioned more often.
    What does AC3 filter do that others don't.
