Zooming and blu-ray
Discussion in 'Plasma TVs Forum' started by Jonstone, Apr 24, 2007.
  1. Jonstone
    Jonstone
    Feb 12, 2006
    4,159
    Prestatyn
    +544
    Simple question really.
    I have a 37PD60 panasonic plasma, sd version of the PX60 and I guess one of the few sd plasmas with an hdmi port.
    When you set your screen to zoom whilst watching a blu ray over hdmi, does the screen crop the picture and then scale it or does it scale it and then crop it?
    I am firmly in the OAR camp these days, but I was playing around with Casino Royale on Blu ray and when you zoom the picture it doesn't seem to demonstrate the same loss in detail that you would get from a dvd source.
  2. UKseless1
    UKseless1
    Mar 9, 2005
    842
    28
    +36
    Probably has something to do with the fact that you were downscaling to begin with and that there is more resolution to play with than on an SD DVD.
  3. Jonstone
    Jonstone
    Feb 12, 2006
    4,159
    Prestatyn
    +544
    Which is basically what I was asking, does it:
    1) Scale the original image to the resolution of the panel and then process that information when I tell it to stretch the image to fill the screen
    or does it:
    2) Take the original 1920x1080 image, crop it, and then scale it to the resolution of the panel?
    Option 2 should give much better results which seems to be what I am seeing, or is it just that the quality overall is better so the resolution loss from stretching isn't so noticeable?
