Zoom H4n or macbook?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by gaddster, Jan 12, 2012.
  1. gaddster
    gaddster
    Mar 13, 2010
    149
    Liverpool
    +10
    Hi Guys
    I am about to start a small project, several interviews and extra footage for a community project. Using a TM900 for imaging and bought a rode videomic pro, plus a Rode lavaliere mic for interviews.
    BUT do I get the H4n recorder or should I make use of the Macbook pro I have to capture the interview audio via the rode lavaliere mic?? (i could capture the sound in adobe audition or garageband on my macbook pro etc) I also have an iPad 2 so could collect a small amount on that too (anyone tried this?)
    Any thoughts, problems foreseen or advice before i spend more valuable cash?
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,854
    103
    +459
    I would think a purpose built device like the H4n would be more reliable. It's power requirements are less for a start. Also analogue into a laptop will probably result in more noise (although still may be so low as not to be a problem).
    Regards
    Phil
  3. gaddster
    gaddster
    Mar 13, 2010
    149
    Liverpool
    +10
    Thanks phil
    Yes you're right, the more I researched, the more it became clear that the H4N would suit my needs and be more practical. I never thought about the laptop picking up more noise, good point.
    So I have just ordered one now 😊
