Zoom controls on AE100 in VGA/progressive scan
richard plumb
Just thinking about whether to upgrade my DVD player when I get my AE100 (currently have a pioneer DV-505 with s-video out)
I see two options:
1) keep current player, into a proV or similar, into AE100 VGA
2) progressive PAL/NTSC player (Philips 962SA?) into component inputs on AE100
One concern I have is what happens with the VGA inputs? Do I lose my zoom controls, so if I'm playing a letterbox movie like Titanic, will I have to watch it in a tiny postage stamp in the middle of the screen.
What happens to anamporphic content? As the DVD player will just be outputting a 4:3 squashed picture, can you still stretch it on the AE100, or does the ProV do that for you?
And does 4:3 material stay with bars left and right (that's how i'd want it)
thanks for the help :)
johnny
Hi Richard,
I have my sony 735 outputting s-video into the Prov which is then VGA into the Panny.
The controls you get with VGA are 4:3, 16:9 and V-Scroll.
For non-anamorphic widescreen DVDs it is a bit of a pain, as there is only v-scroll which slightly zooms the picture (but leaves narrow vertical black lines either side of the image) and allows you to move the image up or down by a few lines.
For images wider than 1.85 then you will also have thin lines above and below the image as well.
But its not too much of a problem as I can count the number of non-anamorphic 2.35 dvds i have on one hand.
