zonealarm completely screwed up
Discussion in 'Computer Software & Operating Systems' started by Giraffe76, Nov 29, 2010.
  1. Giraffe76
    Giraffe76
    Feb 15, 2008
    872
    Coventry
    +17
    Hi all,
    Somehow zonealarm has lost some of the main program files (eg zlclient.exe) and now i have the situation where i cant uninstall the program through any means as the files arent there, i also have a strange situation where the program version is higher than the latest one i can download from filehippo.com so even if i could remove all of the program from my computer would i be able to install the program again at the lower version?
    What would be the best thing to do as im at a bit of a loss..
    Regards
  2. Giraffe76
    Giraffe76
    Feb 15, 2008
    872
    Coventry
    +17
    Ive sorted the problem by finding the uninstall program exe file and running it.
