Zone 2 Zone 3 Zone 4
T
The WB
Ever since i have upgraded my a1xv i have noticed that my amp zones are coming on every now and then. Does anybody why it is doing that? and what is the solution.
Jase
You can switch them OFF via the remote. You have to select each Zone on the remote then just select OFF. Do Zone 2, OFF, Zone 3, OFF etc.
T
The WB
yeah i've done that, but i don't understand why they keep coming on every now and then
Jase
Strange. Mine stay off once they've been switched off. One of the other members had a similar problem every time he turned the unit off the Zones came back on again. I never physically power mine down completely but just switch it into standby. Is that what you're doing?
T
The WB
no just on standby. it never used to do it before i did the upgrade. but then again we did have a power flicker ( Where the lights go off and on in a sec) it happened then. im going to keep an eye on it but i tell you what im not sending it to repairs for that.
Similar threads
