zinwell scaler.
Discussion in 'Projectors, Screens & Video Processors' started by knobbs, Jan 2, 2005.
  1. knobbs
    knobbs
    hi read many threads on this scaler seems it works great on a lg px4211 which ive got wheres cheapest place to buy one of these-is there a big difference between the zinwell 2000 and the 3000-are they available from the uk-thanks knobbs
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    not sure but there is an Iscan ultra in clasifieds for £300 excellent bit of kit for the money or LumagenDVI at £800 which is where proper scaler stuff starts (price wise)
  3. Family Guy
    Family Guy
    The Zinwell briteview 2000 has been dis continued in this country...the Iscan Ultra is a de-interlacer, not really a scaler as such...
    However, as Horny points out, you can't go wrong with a Lumagen. Gordon@convergantav is the sole UK distributor for these in and is a regular on theses forums.
  4. knobbs
    knobbs
    thanks for replys-i heard the lumagen is complicated to set up theres a zinwell on ebay for 329 think its from usa is that pricey-cheers knobbs.
  5. knobbs
    knobbs
    its the 3000 pro model.
  6. Family Guy
    Family Guy
    Got a link?
  7. kenindubai
    kenindubai
    Check out the ebay listings for Zinwell 2000's. I just got one from "av-link" via ebay at £200!!!!
    Great gear at a great price. Even shipped it to Dubai where I live for 25 quid!
    Kenni :) :clap:
  8. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Keene electronics have started to sell the Zinwell again, its the new version with the DVI output :thumbsup:
  9. mike543
    mike543
    Jan 2, 2005
    215
    anyone know why i plug dvi cable into zinwell dvi out and into dvi in on the lg rzpx11 i get a pink screen on top of the video. i have never used dvi before and bought a dvi cable from local computer shop. might have bought the wrong thing here, but i do not know. rgb out works ok.
    Please could someone help
  10. absthechatter
    absthechatter
    Nov 27, 2004
    159
    That can happen if you chose component as the input, when you are really using s-video or composite (the source one and source 2 on the remote).
    Abs
  11. mike543
    mike543
    Jan 2, 2005
    215
    i have found out that if i connect to the plasma(from zinwell 2000 dvi to LG-RZpx11) via dvi and use rbg signal from the zinwell, i get a picture, although not as good as rgb vga, but if i flick the switch to YPbPr, the picture has a pink colour all over it. the pic underneath looks quite smooth in 720 50hz mode.
    anybody any suggestions to why
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    pink is due to the DVi not supporting YPbPr (may need setup changing or might not be compatible at all)
  13. mike543
    mike543
    Jan 2, 2005
    215
    i have tried connecting the zinwell to the plasma via vga and dvi. if i switch the signal to component when connected to dvi, screen pink, when i connect vga, screen green, switch to rgb mode on either connection it is ok. any help please.
  14. Family Guy
    Family Guy
    That's because the Zinwell won't pass a component signal correctly via DVI or VGA...iof you want to use component, you need to connect a component cable and set the plasma input to component...(providing your using a panasonic Plasma that is...haven't read the whole thread...)
  15. kenindubai
    kenindubai
    Careful!!!
    I have now had my Zinwell 2000 DVI for a while. The picture is actually better on my plasma without the Zinwell! I have wasted my money. Try before you buy.
  16. knobbs
    knobbs
    theres a zinwell for sale brand new on ebay got dvi out.
    type in sellers name chelly-claret-n-blue
  17. jonny m
    jonny m
    Mar 22, 2002
    405
    knobbs
    I have a zinwell avt-3700 for sale now I've upgraded my pj, its not the dvi model but it seems the vga output is better with this setup that dvi anyway.
    Let me know if interested.
    J
