zinwell pv 500 remote and marantz rc5400.
Discussion in 'Home Cinema Control & Remote Controls' started by dannav, Nov 11, 2004.
  1. dannav
    dannav
    hi i have a zinwell pv 500 remote for a teletext unit and a marantz rc5400 touch screen remote. the marantz seems to have learnt all the ir codes from the zinwell but will not controll the pv 500 teletext unit.can any one let me know if they have had the same problem or may confirm that the two units are not compatable.thanks dann. :confused:
