Zinwell ProV or Briteview for AE-100
Discussion in 'Projectors, Screens & Video Processors' started by chalkdust, Sep 15, 2003.
  1. chalkdust
    chalkdust
    Jul 8, 2003
    612
    +11
    If anyone has any experience of these two, which is the best value choice given the PJ it will be used with in the pound vs performance stakes. Is it a ProV given the PJ will be used for at least a year with it. Is the jump in quality worth the extra.
  2. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Check the FAQ for links to posts about both of these items - a start, at least.......
    Sean G.
  3. Kramer
    Kramer
    A "cheap & cheerful" HCPC (or PC even) will beat either hands down.
    Why have milk when you can have cream? :D
    Worth trying (even briefly) IMO.
  4. gingercat
    gingercat
    Nov 19, 2002
    489
    Lancashire, UK
    +26
    I would say that unless you really do need a standalone TV tuner for the AE100, don't bother with the ProV, the AE100's internal de-interlacer does a much better job - I tried a ProV with mine and wasn't at all happy with it. If you're not going the HTPC route, consider using a VCR composite video out to supply your TV signal to your projector.
  5. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    Kramer, I'm in the middle of buying an HCPC but I'm worried about the deinterlacing as the reviews of all the software dvd players on Secrets of Home Theatre say that they are flag reading only and don't do motion adaptive.
    The brightview is a motion adaptive deinterlacer and fairs better than all the software players on test.
    See here.
    So in what way is the HCPC better?
    To stay slimmer? ;)
    Chalkdust, I've not seen the units in action but by specs and reviews the Briteview seems a far better choice.
    There are also a couple of iScan pro's for sale in the classifieds here for £225 and £300 which is supposed to be even better although they don't scale.
    Cheers,
    Cal.
  6. chalkdust
    chalkdust
    Jul 8, 2003
    612
    +11
    Thanks for all the informative replies. Think it is a little clearer now but with a few more variables to add to the equation. Have read excellent things about i-scans, are they completely different beasts to the Zinwell products or just more of the same.
  7. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    The main difference is that the BriteView is also a scaler (it scales up or down the resolution of the signal) of the as well as a deinterlacer (turning interlaced signal into progressive scan). The IScan is only a deinterlacer.
    However you'll find that while most budget projectors have pretty good inbuilt scalers, they only have basic deinterlacers (as this is more expensive to do well) making the latter more desirable.
    I think the Briteview scales to 480p, 576p, 720p and 1080i (the number is the number of vertical lines and p is progressive while i is interlaced).
    If your pj does not fall into any of those catagories (mine doesn't as is 960x540) then the pj will still have to do some scaling itself.
    The best product for scaling is an HCPC which in most cases (the AE300 is a notable exception) will be able to scale to the exact resolution of the projector ie 1:1 pixel mapping.
    A set top scaler is therefore more important for a crt pj.
    Therefore you should be more interested in deinterlacing performance with 576p for PAL sources and 480p for NTSC.
    The generally accepted pecking order is:
    iScanUltra ~ iScan Pro > BrightView (and its clone) >> ProV+ >
    Pro V.
    There's other stuff like Lumingen's but unless you have a crt pj we're talking sledgehammers and walnuts.
    One reason that the iScan is better is that it does diagonal processing for jaggies on moving diagonal lines. It removes the jaggies by doing something a bit like antialiasing in graphics packages.
  8. chalkdust
    chalkdust
    Jul 8, 2003
    612
    +11
    Thanks calscot, I have a panny AE100 not wealthy enough for a crt, I'll keep an eye out for one of your recs.
    cheers
  9. jGrahamD
    jGrahamD
    Feb 11, 2002
    259
    I believe ATI PC graphics cards are supposed to have excellent de-interlacing.
  10. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I'm only just in the processing setting up my AE300 but from what I've only read on the subject even though 1:1 mapping isn't possible one can get as near as dammit and get excellent results even so.
    Surely de-interlacing is done by the software not the graphics card?
  11. jGrahamD
    jGrahamD
    Feb 11, 2002
    259
    ATI cards support "adaptive" de-interlacing in hardware, which is supposed to be superior. I don't know if you need the ATI DVD player software to utilize this.
