ZINWELL BLS 2000DVI Scaler
Discussion in 'Plasma TVs' started by Setch, Mar 12, 2005.
  1. Setch
    Setch
    Jan 31, 2005
    71
    9
    Anybody have any knowledge of this product?
    Brite-View BLS-2000 Features Overview
    • Accepts Composite Video, S-Video or YCbCr from any PAL/NTSC video source
    • Scales up to 1280x1024 (SXGA) and 720p (HDTV) resolutions
    • RGB or YCbCr component output
    • Infrared RC with hot keys for Input selection, Picture settings, Resolution and Output format
    • Dynamic digital 3D Comb filter for excellent separation of Y/C signal and improved resolution
    • Dynamic chrominance transience improvement by synthesising faster colour edges
    • Pixel base motion detection to implement Bob and Weave methodology in the same picture
    • Black level extender to improve the contrast
    • Motion adaptive noise reduction to reduce noise in non moving parts
    • Dynamic adaptive smoothing filter to remove the high frequency noise
    • Adaptive static de-interlacing doubles the resolution of non-moving portions of the picture
    • 3:2/2:2 Pulldown detection and correction for best viewing of filmbased sources
    Technical Specifications
    Input signal
    Analogue: Composite Video (1Vpp), S-Video (Y:1Vpp, C:0.3Vpp)
    Digital: Component Video, YCbCr (Y:1Vpp, CrCr0.7Vpp)
    All PAL and NTSC video standards
    Input connectors
    Composite Video: RCA
    S-Video: 4pin, mini DIN
    YCbCr: 3x RCA
    Output signal
    Hardware switch selectable between VGA and YPbPr (Y:1Vpp)
    Analogue RGB (0.7Vpp, TTL Sync) Resolution: 640x480 (VGA),
    800x600 (SVGA), 1024x768 (XGA), 1280x1024 (SXGA)
    Analogue HDTV (YPbPr, 0.7Vpp, Sync on Y), resolution 480p, 720p, 1080i
    Progressive scan video (line freq 31.25kHz, for PAL and 31.5kHz for NTSC
    Refresh rate: 60Hz
    Output connector
    D-sub 15pin, Female type
    Video processing
    AD and DA conversion
    10bit ADC and 10bit DAC
    Y/C separation
    Programmable 3D adaptive Comb filter with colour edge enhancement circuit (reduces cross talk and improved colour resolution and sharpness)
    De-interlacing
    Adaptive static detection (improves sharpness by doubling the resolution of non-moving portions)
    Pixel base adaptive motion detection implementing Bob and Weave methodology on same picture (picture 'clarity' is enhanced by applying Bob to motion part and Weave to static part of
    picture)
    Automatic 3:2 (NTSC) and 2:2 (PAL) pull down detection (regenerates original film pictures)
    Noise reduction
    Dynamic adaptive smoothing filter (reduces high frequency noise)
    Motion adaptive Infinite Impulse Response filter (reduces noise in non moving parts)
    Dynamic Picture Enhancements
    Chrominance transience improvement (improves colour sharpness by synthesising faster edges)
    Scan velocity modulation (ensures sharper picture details when there are edges in the picture)
    Black level extender (extends grey to black level to improve contrast)
    Automatic Brightness/Contrast adjustment (depending on picture content)
    White peak level restrictions (limits white level of picture)
    Automatic colour temperature correction (adapts Y/C gain to make colours more vivid)
    Remote control/On screen display
    Hot key selection and adjustment of all picture settings (contrast, brightness, colour, tint, sharpness, resolution, display format, language)
    Hot key input selection (YCbCr, Video, S-Video)
    OSD languages: English, German, French (others available on request)
    Power: Adapter with 100–240VAC (50/60Hz) In and 12VCD 1.25 Amp Out
    Consumption: 15 Watts typical
    Operating conditions
    Temperature: 5–45 degrees C
    Humidity: 5–80%
    Dimensions: 206(L) x 157(W) x 45(H) mm
    Weight: 1080 grams
