Zinwell 2000 Scaler problem.
Discussion in 'Projectors, Screens & Video Processors' started by chuffster2005, Mar 6, 2005.
  1. chuffster2005
    chuffster2005
    Dec 27, 2004
    646
    28
    +85
    Set up my the Zinwell with DVD plaer running through component and SKy running through S-Video,output from Zinwell was through DVI toDVI to my plasma tv.
    All worked fine for a couple of days,then suddenly,all I got through the dvd signal was a load of flashing lines!No picture whatsoever,as if it was a tv channel that needed to be tuned in!!Is the unit knackered? :mad:
  2. Mike Khain
    Mike Khain
    Hello,
    The problem you might have is either dvd player is selected to progressive scan or the switch on the back of the Zinwell is flipped up to the YprPb ( if you would get it to the normal RGB as required for DVI) it should start working as before.
    Thank you
    Best regards,
    Mike
