tdhtdh
Hi all
Really struggling to find out an answer to my query.
I've got some Linkind smart bulbs that came with a zigbee hub
Amazon product
I've added some Linkind E14 bulbs which work fine.
I also have an IKEA gateway and 2 bulbs but you have to connect each device to a remote and don't seem to be able to add non IKEA products to it.
I then bought some Osram Smart+ bulbs as they were Zigbee I assumed the Linkind Zigbee hub would work with them. They both said Zigbee right, so you'd assume they work right? Oh no, they don't.
Amazon product
I have an Amazon Echo Show 8 1st gen which doesn't have a zigbee hub
Amazon product
It's getting kind of messy with different products, different gateways etc so I'm looking for something that would allow me to just add zigbee products easily.
I believe I could buy an Echo 4th gen as that includes a Zigbee hub but I don't really need another speaker so I'm wondering if there is a zigbee hub out there that doesn't lock to its own products?
For example would this work?
Amazon product
Would getting the philips hue bridge do the trick?
Many thanks
Amazon product
Amazon product
Amazon product
Amazon product
Many thanks
