Quantcast
ZIDOO Z10 / Z9s 4K HDR Owners Thread
DELUCAS
Thanks all. I couldn't wait until the weekend so the Zidoo is now back up and running and appears to work well with some of the files that the Apple TV/Infuse couldn't use.
One strange thing I have found is that the Zidoo doesn't seem to pick up all of the files on the NAS drive. One of the files I was having problems with was the original Mission Impossible film. When I go into the library, there is a poster for 'M:I Collection' but it only has two films rather than all of them.
I have checked all of the other posters to make sure they have not been mismatched and also the 'Other' folder for the ones that have no match, but I can't see the files there.
Do I need to rescan to find these files, and if so will that undo the manual updates/rematches that I have done?
Try a rescan 3 times to find all your library etc
or check your on the latest firmware on your X9s ?
Furnace Inferno
Make sure you’ve checked everywhere, like A,B,C tracks in the other mission impossibles and everywhere else. I think I remember it doing the same for me with those titles.
DELUCAS
Must be due an software update soon ....... :)
Jonesthegas
My Z9s still will not update online. Anyone know how to fix this?
DELUCAS
wasssu
Is it possible to make the hdd (connected via sata port) as default storage on Z9S? I want to use an app torrent and download directly to hdd.
Kai Winters
I had two freezes yesterday. The first was watching "Enemy at the Gates". It froze about a third of the way through. No controls on the remote worked. I had to shut off the Z9S and restart it. When I went back to the movie it resumed without problem.
Same problem later in the evening while watching episode 4, season 3 of the Big Bang Theory. Had to do the same as above.
Prior to this I downloaded and installed the latest update from the site. The process went smoothly and appeared to work fine.
After the freezes I followed the instruction to get to the developers section and shut off EDID based on posts I've read. But I don't understand what EDID is nor what it does...I'd be grateful for an explanation.
I use 2, 4tb/5tb WD EasyStore usb hdd's that are connected to the udb 3.0 inputs.
I've not had any freezes before so I'm a bit stumped.
Thanks for any help.
DELUCAS
for now connect via usb 2 ports
hearing an issue with usb3 poss req power for some usb drives ?
read first page on this thread for tips .
Kai Winters
I've moved the hdd's from the usb 3 ports to the usb 2 ports and have not had a problem with a show freezing.
Thanks for the suggestion.
Really like my Z9
rocket1
Do these players have the ability to play files automatically after each other? Eg S01E01, then S01E02 then S01E03?
DELUCAS
Beta ! Beta ! Z10 coming soon .......
Model: ZIDOO_Z9S
Version number: v2.3.3
System
1. Optimize the problem of the USB 3.0 port even if the device is lost
2. Fix the problem that DTS track music cannot be played
3. Fixed the issue that HIFI music will not play automatically next time
4. Optimize online playback
5. Increase the global press "Information" key to display the current HDMI output information
6. Optimized the problem of abnormal sound after DTS music playback is paused
7. Fix the problem of abnormal sound of Bluetooth device when HDMI output is set to source code output
File manager
1. Fix the problem that the same share name is displayed in NFS
2. Cancel the top navigation category and add the list rotation function
3. Added CD disc insertion tips
4. Optimize sorting function (save separately by path)
5. Added the function of pressing "Popup" to return to the top of the list
6. Fixed the problem that the played video does not prompt the watched icon
Poster wall
1. Optimize the display of the details interface and the movie video
2. Optimize segmented video scanning
3. Optimize scanning to solve the problem that stopping scanning during scanning may cause unmatched videos to not match properly when continuing scanning
4. Solve the problem that the child lock set is not displayed synchronously after the movie rating is initially set
5. Increase the HDR corner mark (scanned videos will not be displayed)
6. Optimize file name recognition
7. Optimize application stability
8. Optimize bracket processing for title recognition
9. Added trailer filter filtering, the word 'trailer' in the file name will no longer be scanned
10. Optimize the NFS mount method
Music player
1. Optimize folder browsing function
2. Add CD playback function (requires external optical drive)
3. Optimize the sorting function
4. Optimize the calculation method of scanning progress
5. Optimize track identification for SACD and CUE albums
6. Improved the interface of obtaining track list, and solved the problem that CUE / DSF track list cannot be obtained by the mobile phone
7. Modify the time display format of CUE to keep the same with SACD
8. Optimize focus control logic to solve the problem of focus flicker
9. Modify the recording method of the playlist to solve the problem that the last song in the random play mode will be rerandom.
10. Added screen saver function in play details interface
11. Fixed an issue where the list interface displayed an error after the grid layout removed the list
12. Fixed the problem of getting albums when playing music from file manager
13. Fixed the problem that the lyrics could not be closed without playing the details interface
Local player
1. The problem that the optimized bit rate is displayed incorrectly
2. Fix the problem that the movie name is displayed incorrectly
3. Add ZOOM function
4. Increase the video ratio
5. Fixed the issue that Polish subtitles are displayed in Portuguese
6. Optimized subtitle download function
7. Optimize the front panel USB icon display
8. Optimize the problem that DVD cannot select chapters
9. Optimize ASS subtitle display
Blu-ray navigation
1. Added the function of subtitle track list displayed by shortcut keys
2. Optimize subtitle download function
Mobile APP (need to update mobile app v.1.5.3)
1. Add audio offset setting in the setting interface
2. Folder browsing function has been added to the music device interface
3. Application interface adds sorting function
4. Fixed the problem that the same device is repeatedly added to the music device interface
5. Fixed the issue that the CUE / DSF track list cannot be obtained from the temporary list songs
6. Optimize the problem that the application interface icon is not displayed
7. Optimize poster wall interface display
8. Solve the problem that the file management is affected by the search bar, and it will return to the upper directory when rescanning SMB or NFS
9. File manager adds list refresh function
10. File Manager adds CD-ROM drive list
Posted on
@ZidooNews
Android TV Box:
Zidoo #Z9S
#Firmware
Version: 2.3.3
Stage: #Beta
Package: #OTA
Blenky
No mention of the important issues such as seamless branching
Kai Winters
Hi all,
What is the largest size usb external hard drives are you using? My largest is a WD easy store 5TB. I'm considering a large 10-14TB external. Is anyone using one this large.
Also what about sata drives? What are you using? How large, etc.
Thank you.
Furnace Inferno
I’m using 20TB WD My Book DUO’s, no issues except the standard USB 3.0 one.
satsid
Recording from one HDMI while using both HDMI,while watching other one is cutting off with version v2.2.96. Do I need to change setting? if yes has anyone have a link please.
cheers.
Kai Winters
Installed 2.3.7 today...went well, no problems. It fixed one problem I had...at the end of watching an episode of a sitcom, Big Bang Theory, it would go back to the folder then black screen for 5 seconds, yep I counted lol, then back to the folder and ready for play...now it goes back to the folder and ready to play.
I did lose the avr display screen that would appear when changing the volume...not a big deal but a surprise.
Happy New Year !
m206
Hi everyone, I've a z9s and a yamaha rx-v775 (hdmi 1.4 no HDR). to avoid to replace my 775, i've tried to connect the z9s to yamaha with optical spdif, it seems to work but sometimes the sound disappear for 1 second. I thought the cable could be the problem, but I've tried the it with another player (popcorn hour a-410), and the sound is perfect. right now i don't rememeber which fw version i've, do this issue happened to some of you? any ideas/solutions? many thanks in advance.
DELUCAS
why are you connecting via optical ?
use Hdmi always .
m206
because my old AVR yamaha rx-v775 doesnt support HDR.. i'd like to keep it, it still sounds great.
DELUCAS
Regardless if it supports or not you should still use hdmi connection hdmi 1.3 or 1.4
you will still receive a stunning picture .
unless your using a 4K screen etc
m206
Sorry if i forgot to mention, of course i've this problem since i want use a full 4k Hdr, i've a sony 75xf9005 4k hdr tv and i want to get hdr working, i've tried with the tv player and the differences between hdr and non-hdr are stunning.
DELUCAS
No 1 make sure you are on the latest firmware 2.2.96
Using H.T.v2
and no bloat wear on and often shut off and un plug Zidoo player often etc .
DELUCAS
ZIDOO_Z10 New Firmware v2.3.10 Beta
New please be aware this is a Beta Beta !!
Model: ZIDOO_Z10
Version number: v2.3.10
Changelog
(From here, translation via Google Translate.)
(original text below) / (оригинал ниже)
System
5. "Information" key, display the current HDMI output information
8. Fixed the issue that Dolby Atmos audio freezes in some individual film sources
9. Optimize DLNA projection function
File manager
1. Fix the problem that the same share name is displayed in NFS (for Usbshare multiple external hard disk cabinets, only one can be found)
7. Modify the problem that the volume label does not display more than 20 characters
Poster wall
11. Fix the problem that the background service causes the setup wizard language to be incorrect
12. Fixed the problem of disordered video in the folder video list interface
13. Fixed the problem that poster information cannot be obtained based on the file path
14. Fixed the problem that the total number of videos on the device does not change after moving the video out of the poster wall
15. Clear device and delete device will remove related video information from database
16. Fixed the issue that the poster does not refresh after modifying the rating of the child lock
17. Child lock setting interface adds function description and child lock reset function
18. Optimize the collection function
19. Fixed the issue that playback records cannot be saved when playing NFS source
20. NFO added sorttitle field support, only use this field for sorting in movie collection interface
Music player
6. Improved the interface of obtaining track list, and solved the problem that the mobile phone cannot control the CUE / DSF track list of the temporary list
14. Fixed the problem that sometimes the detailed interface picture cannot be obtained
15. Added automatic full-screen playback switch
16. Added music file information display to the list
17. Solve the problem that search interface focus may be lost
18. Fix the problem that the song is cut abnormally in the playback interface
19. Modify singer details interface
-Add album sub-categories, you can directly enter album details from the list
-Add picture subclasses, you can set the default, delete and add operations for pictures
-Add details sub-category, you can browse all the information of the singer
20. Add "View Artist" and "View Album" functions
21. Add song names that do not match the file name "track + number"
22. Fixed the problem of flashing back when pressing the "Home" key in the folder song interface
23. Fix the problem that Bluetooth remote control connection stops playing
24. Add multi-folder scanning. The abnormality will be displayed after the scanning is completed, and the normal display will be restored after all scanning
25. Fix the problem that the time of the song displayed on the front panel is incorrect
26. Fix the problem that the sample rate of the playback details interface is incorrect.
27. Fix the problem that some DTS-CDs cannot be played
Local player
10. Fixed the problem that the srt subtitle space is not displayed completely
11. Fixed the problem that the file name of the DVD folder was displayed abnormally during playback
12. Optimize the setting of video scale interface display
13. Add sequence play function
Blu-ray navigation
3. Fixed the problem of incomplete display of srt subtitle space
Quick settings
1. Add ignore EDID function
2. Add video sequence playback function
Scheduled shutdown
1. Modify the problem that the traditional display is abnormal
Picture manager
1. When optimizing the slideshow, the picture is blurred
Weather
1. Optimize the problem that the weather is not available in some cities
Mobile APP (need to update mobile app v.1.5.5)
Gofile Mirror: Gofile - File sharing platform, anonymous and free
How to upgrade: HOW TO UPGRADE A ZIDOO X9S BOX BY OTA
MD5 Hash: 6915C10FF9D6D9CFA35A68E5F54CC945
Trending threads
Latest News
Disney+ announces discount for European launch
  • By Andy Bassett
  • Published
Disney developing AI based video compression
  • By Andy Bassett
  • Published
Vizio announces Disney+ available on SmartCast TVs
  • By Andy Bassett
  • Published
Audio-Technica reveals Kokutan and Asada Zakura headphones
  • By Andy Bassett
  • Published
Sky announces combined Sky Sports and BT Sport packages
  • By Andy Bassett
  • Published
