DELUCAS
Tips :
1 : Boot time : 29.76 seconds with background photo added
2 : When updating firmware download as is dont touch it and just copy paste to usb stick
and let zidoo locate it and it will test and unzip it for you .
3 : Once firmware is installed power off box then unplug from the mains for a few seconds then re-attach to the mains and power back on the Zidoo Box . ( just helps re-set the zidoo )
4 : Go to apps long click on Home Theater v3.0 app menu appears highlight Boot straight to Home Theater v3.0
and when you power on your X10 it will go straight to the Home Theater v3.0 screen .
5 : Z10 can take a 3.5 inch drive or a 2.5 inch drive with a caddy .
Ssd Drive for Silent operation and no fan enabled . [ which i have tested ]
6 : Dont clog Z10 with many downloaded apps [ Bloat wear ] it can make it struggle and cause issues try keep it minimal as possible as they use a lot of resources and run in the background and can cause crashes etc
7 : Boot time from power on to home screen approx 29.76 .
8 : It pays to physically unplug the unit from the mains which re sets the unit and defrag it on occasion if you experience some odd issues .
9 : Where to buy from : High Performance Media Boxes - UK BASED - futeko.com
10 : How to add Badge icons on H.T.v3.0 so add description in file name :
Ghost in the Shell (UHD-HEVC)(TrueHD Atmos).mkv
- (4K) = 4K badge
- (3D-AVC) = 3D+H.264 badge
- (UHD-HEVC) = 4K+H.265 HEVC badge
- (AVC) = H.264 badge
- (HEVC) = H.265 HEVC badge
- (AVC) = H.254 MPEG-4/AVC badge
- (DTS-HD MA 5.1/7.1) = DTS-HD High Resolution Audio badge Dolby
- (TrueHD) = TrueHD badge
- (Dolby) = Dolby Digital badge
- (DTS) = DTS badge
- .iso = ISO badge
- .mkv = MKV badge
Z10 Firmware : v2.3.32
New firmware v2.3.32 version for ZIDOO Z10 release
Zidoo released a new firmware for their model Zidoo Z10 https://www.mcbluna.net/wp/zidoo/zidoo-z10-firmware-v2-3-32/
Z10 Firmware : v2.3.30
Z10 Firmware : v2.3.10
Z10 Firmware : v2.2.96
Z10 Firmware : v2.1.22
http://apidl.zidoo.tv/Z10/v2.1.22/ZIDOO_Z10_N_v2.1.22_201812292156_ota-package.zip
Z10 Firmware : v2.1.30
http://ota-cloudfront.zidoo.tv/Z10/OTA/ZIDOO_Z10_N_v2.1.30_201901082110_ota-
package.zip
Z10 Firmware : v2.1.40b
http://apidl.zidoo.tv/Z10/v2.1.40/ZIDOO_Z10_N_v2.1.40_201901250933_ota-package.zip
ZDMC : 18.8
http://apidl.zidoo.tv/app/zdmc-18.8_rtk.apk
