DELUCAS
Will put it down to user error !Works like a honeybee now changed the above complain tot a.praise. Fair is fair. Thanks for the help.![]()
Glad sorted
1. Optimize online video 2.35:1 function
2. Optimize the problem of no sound in individual AAC audio playback
3. Add original ratio DAR function to local video
4. Local video optimized PGS subtitle brightness settings
Quick Settings
1. Add the function of turning off the cable network prompt light
2. Add the function of manually adding WIFI
3. Increase the password display function of the WIFI password input box
4. Optimize the function of clearing system application data
5. Increase screen masking and only compress GUI settings
poster wall
1. Fix the problem of quick click to reset custom layout app crashing
2. Fix the problem that the movie marked as finished is played again without restarting
3. Optimize the focus of the movie details video list
4. Optimize some translations
5. Add ignore TV series saison words
6. Fix the problem that the video does not play immediately after clicking to play
7. Add boring mode function
8. Remove scan default ignore words
9. Fix the problem of exporting the collection picture error
10. Fixed the problem that the original music cannot be closed in the classic list mode
11. Fix the problem that the home button exits and the application crashes occasionally during scanning
12. Fix the problem that the English letters of the classification and sorting interface are not displayed completely
13. Fix the problem that the scanning filter folder does not take effect
14. Add the editing functions of "All" and "Device" widgets in the main interface
music
1. Add the function of automatically playing the songs in the playlist when starting up
2. Optimize CD playback
3. Optimize the problem of missing album and artist title characters
Wonder what number 3 means?
Hi, I have just set up a Z9X with my LG 55E6 and everything is fine except for one thing that I am hoping someone can point me towards the solution or an explanation, the problem is that 4K DV mkv's are playing back at 1080p 60hz...All non DV mkv's playback perfectly.
I have done a quick search on google and have not yet been able to find an obvious solution or answer to this, but I have noticed that older LG TV's seem to have a problem with this.
Thanks for any help.
Yes I have used your settings thanks and after double checking I have discovered the problem, it was solved by changing the Dolby Vision Compatible Mode to Priority standard DV (TV Led).…This box has a lot of settingsAte you ising these settings ?
Playback/Automatic frame rate/Frame rate mode: Switch frame rate and resolution *
Display/HDR: Auto **
Display/Color Settings/4K 50~60Hz: Priority YUV420 10BIT
Display/Color Settings/4K 23~30Hz: Priority YUV444 10BIT
Display/Color Settings/Non-4K: Priority YUV444 8BIT
Display/Color Settings/HDMI Range: 16-235 ***
Display/HDMI Mode: 3840x2160p 23Hz ****
Audio/HDMI Audio: AUTO *****
Audio/Downmix HD Audio output: OFF
Display/MaxCLL and MaxFALL: ON *
Display/Colour Settings/Deep Colour Compatibility Mode: OFF **
I can't wait to see what #7 actually does![]()
Dont know how Tesla got involved there .![]()
I don't have a Tesla but it has a Toyota Prius mode?
Thanks and yes it is, I have already solved the problem as posted above...I changed the "Dolby Vision Compatible Mode to Priority standard DV (TV Led)" instead of "LLDV (Player Led)" and I now have perfect automatic frame and rate switching.Aren't the LG OLED 6s limited to 30hz for Dolby Vision?
1. Are you trying to force 60fps out from the Zidoo?
2. Can you post media info of the problematic DV MKV files?
I now have a new problem, I was watching a film last night and after roughly 30 minutes the TV went into standby mode while the Z9X & Receiver carried on working. I haven't had the time to look into it yet, but I also have a Vero 4K & Apple TV 4K and have never had this happen.
I already have CEC off as I prefer to use my Harmony remote, not sure about HDCP so will check that later...Thanks.Just for trouble shooting if nothing to do with your tv ?
switch off cec on Zidoo etc
& Hdcp Off on Zidoo
All Models Firmware : Beta v 6.3.75UHD3000
v6.3.75
http://apidl.zidoo.tv/uhd3000/v6.3.75/UHD3000_P_v6.3.75_202201221844_ota-package.zip
MD5: 71D3BBB6DC63AFE0808A96B5EF2E22F0
v6.3.75_G
http://apidl.zidoo.tv/uhd3000/v6.3.75/UHD3000_P_v6.3.75_G_202201221845_ota-package.zip
MD5: 15C751084DADA7EB7FA3AA3E4304275B
Z1000 Pro
v6.3.75
http://apidl.zidoo.tv/Z1000_PRO/v6.3.75/Z1000-Pro_P_v6.3.75_202201221817_ota-package.zip
MD5: 14559F340A05D7368688D19D8D1DF5C6
v6.3.75_G
http://apidl.zidoo.tv/Z1000_PRO/v6.3.75/Z1000-Pro_P_v6.3.75_G_202201221819_ota-package.zip
MD5: E2BD9F4AEB923C9D3A58DFC75A019C53
Z10 PRO
v6.3.75
http://apidl.zidoo.tv/Z10_PRO/v6.3.75/Z10-Pro_P_v6.3.75_202201221659_ota-package.zip
MD5: 652FCDA353ADE6DED79F075417EB6843
v6.3.75_G
http://apidl.zidoo.tv/Z10_PRO/v6.3.75/Z10-Pro_P_v6.3.75_G_202201221709_ota-package.zip
MD5: 03441F6DE21B440EA93B9B37C9C34D37
Z9X
v6.3.75
http://apidl.zidoo.tv/Z9X/v6.3.75/Z9X_P_v6.3.75_202201221741_ota-package.zip
MD5: 802F62AC1CF0769846E18FEFE88CE481
v6.3.75_G
http://apidl.zidoo.tv/Z9X/v6.3.75/Z9X_P_v6.3.75_G_202201221742_ota-package.zip
MD5: 35BE5160B545E8F0B4992A6C69908188
thanks will try it after work tonightAll Models Firmware : Beta v 6.3.75
thanks will try it after work tonight![]()
i never had a problem with it maybe with earlier firmware but at the speed they releasing a non issue.See if Auto Trailers are back up & working![]()
Pleased with the little update for us scope screen users. Can now set the screen aspect ratio for 2.35:1 just for the GUI.
That bored function where can I find that?,No use for me …..
But good to hear for screen owners
and another tick box ticked
