ZIDOO - Z10 PRO - Z9X - Z1000 PRO - UHD 3000 - NEO A - NEO S - NEO X - Dolby Vision - Owners Thread
DELUCAS
Hello.
Looking at the Ziddo 1000 Pro or the UHD3000 is there any reason to pick the UHD3000 over the 1000Pro the UHD3000 has a dedicated audio output would I miss anything by buying the 1000Pro which does not have a dedicated audio output.
For Music / Movies
UHD 3000 Model is more for the High End Audio stereo 2 channel side of things as such with more storage 2 x 3.5inch drives.
For Movies
If its for Movie Playback mainly the Z1000 Pro be the one to go for if they are your two choices .
Both will give the same Movie Pic Quality output as use same 1619 chipset
More inf on first page of this thread .
Hello.
Can I ask are there any probles with the UHD3000 as I have read on other forums there were a few bugs have they been sorted out does anyone know.
I use the uhd3000 just about every day and never had any problems. I also use two internal 16tb hard drives in it and works perfect
JL12W7
Thank you all very much for replying so looks like as this is a movie only situation then I will plumb for the 1000 Pro. I just wonder why the 1000 pro does not have a dedicated audio HDMI output, though it must not make much difference.
Thatsnotmynaim
Only use full if your AVR doesn’t support all the picture standard you like, eg Dolby Vision, in which case you can send the 4k video direct to the tv and still send the audio separately to your older AVR. Was useful in the early days of 4k but less so if you have a more recent AVR.
JL12W7
Yes my reason for asking is I will have this set up in the AV Room so I would send the video straight to the Projector and the audio to the av receiver. From what you are saying I can do that with the 1000 Pro because there is no reference to that particular setup in the manual I have looked at on line, but from what you are saying that is possible in settings is it.
Thatsnotmynaim
Why can’t you send the video to the pj from the AVR? The 1000 only has 1 HDMI out so can’t do what you want.
JL12W7
Yes I kind of assumed that myself with only being one output but assumed you could change the setting to configure another setup meaning the other HDMI port but now as you have pointed out that is not possible.
I could do as you sggest but I preferred a direct connection from the source meaning media player it saves muddying the water with the avr then connect the sound directly to the Denon A110 so looks like I would have to plumb for the 3000 UHD @ £849. Or do you think there is nothing to be gained doing it my way and just better to do as you suggest connect the 1000 Pro into the avr suppose I could hook it up that way. As it would save me £530 as I can buy this 1000 pro media player for £295. Just looking some advice and what you have stated does make more sense if I am being honest.
Thatsnotmynaim
What AVR do you have, if you turn off osd and all video processing (video conversion) or video scaling you should see little degradation in reality..
JL12W7
Hello as already stated I have the Denon A110
I've tried some of the cheaper ones and still prefer the UHD3000. For me the sound and picture is better. Maybe something to do with the power supply.
Thatsnotmynaim
Great, turn off osd and video processing and see if you can spot a difference picture wise going via AVR or direct, hopefully you shouldn’t see much. With osd and processing you can..
Thatsnotmynaim
I think the UHD1000 & UHD3000 are near identical bar the UHD3000 having dual HDMI out and better DACs for analogue audio. Did you compare UHD3000 vs UHD1000 or just to the lower ones with external PSUs.
markymiles
Umm, same chipset on all of them. So sorry don't think so. Quite a hefty amount of expectation bias going on me thinks.
My friend came up with his 1000 and we compared them on my 4k jvc projector and yes we could hear and see the difference. But on a 65 inch tv screen we could not see any difference. But could still hear the difference. All depends what you are using
Thatsnotmynaim
How was the sound hooked up, HDMI or analogue?
Thatsnotmynaim
Analogue better sound. It is a pity that 7.1 analog imputs are not proposed with 1000pro and 3000
Agree on the analogue, although not bothered by that as have seperate stereo streamers and dacs for that, but was wondering if the better PSU (not dacs) makes a differcence, if I'm reading it right, the suggestion above is a difference in picture and audio was there in a home cinemasetup, i.e. better picture and listening to AV audio via I presume HDMI...
ulises31
Hello.
This a question I ask.
Happy with 1000pro and now I can read my isacd iso multichannel even it is converted in LCPM ( veery hard to listen differences between native and LPCM)
Im hesitating in replacing the zidoo 1000pro by 3000 or dune hd max bor a better hifi sound and better sound in movies.
Zidoo 3000 costs 999€ and dune 640€ buz zidoo has a better dac and maybe a better transformer.
What do you think?
thank you
ulises31
One think more, for the moment none is able to read DVD-Audio with MLP stereo and multichannel. It is a pity. the player only able to schedule Classical stereo and dolby/dts.. Maybe ina next firmware.
markymiles
What exactly was different? And just to be sure your mate had the Z1000 Pro not the previous gen Z1000?.
Latest News
Disney+ confirms price increases coming in December
  • By Ian Collen
  • Published
Samsung unveils Galaxy Z Flip 4 and Fold 4 smartphones
  • By Ian Collen
  • Published
Movies Podcast: 8th August 2022
  • By Casimir Harlow
  • Published
AVForums Podcast: 8th August 2022
  • By Phil Hinton
  • Published
Warner Bros Discovery set to combine Discovery+ and HBO Max
  • By Ian Collen
  • Published
