ZIDOO Z10 PRO - Z9X - Z1000 PRO - UHD 3000 Dolby Vision VS10 Owners Thread
inzaman
I have lotr uhd and I get no stutter using WiFi. I am on .90 beta.
But sometimes my mkvs just freeze up.
Are you running this from a NAS? I am using a drive directly connected by USB but am contemplating NAS although my house is networked with Cat6.
I re-ripped LOTR EE UHD with latest version of makemkv and then updated Zidoo as i was running the original fw which was .4 i believe, hence my question as i have skipped a few versions that corrected these types of issues. My other UHDs ran fine on the old firmware just not LOTR.
DELUCAS
I see this forum is much more up to date than the other one
Does anyone know if the x20 pro can handle 16TB, 18TB drives and if the WD 24TB Duo (2 x 12tb) will work with these units ?
Heard useage of 16tb but format it correctly first .
other sizes poss but cannot confirm .
DELUCAS
Firmware : v6.0.90 is no longer classed as beta
so stable .
saguk1234
Yes I am running this from a nas
55rr66
*****  Enables forcing of 4K50/60 4:2:0 10/12-bit even if EDID does not allow.
(Some TVs can accept this signal even though EDID says it can't)
If your EDID does specify 4K50/60 4:2:0 10/12-bit this setting will have no effect.
If your EDID does not specify 4K50/60 4:2:0 10/12-bit and does not allow it, setting ON will cause picture loss.
unfortunately I did not understand anything from what is written:
where is EDID? In the movie? On screen?
what determines if I get 12 BIT?
if the movie is 8 BIT color how will I get 12 BIT?
what converts the color to 12 BIT 64 billion colors
DELUCAS
What is EDID
My usual basic description is that EDID is the information provided by a monitor to the video source describing the monitor’s capabilities. This allows the video source to then send out a video signal that is supported by the monitor. EDIDs are important for DVI and HDMI video sources and occasionally used for VGA sources.​
What is EDID?
Of course if you really get into it, EDID, which stands for Extended Display Identification Data, is far more complicated. It includes vendor and product id, serial number, manufacture date, size of the display, resolution and frequencies supported, and detailed signal timings for native resolutions. Plus, often when we speak of EDID we are actually referring to E-EDID, or Enhanced Extended Display Identification Data.
55rr66
What is EDID
What is EDID?
Good explanation if I have OPPO that converts to 12 BIT color
how does the ZIDOO Z10 player or one do it?
it is written that the device shows 68 billion colors
that is, it converts color to 68 billion colors?
from 8 BIT?
or shows 68 billion colors if there is a 12 BIT movie?
DELUCAS
Update :
Should be getting a Beta firmware update within a week or two fingers crossed . 🙃🙃
rocket1
Does anyone else have this problem with their Zidoo? Browsing SMB shares, if I access a drive on my PC with folders, the Zidoo never sees the first folder? Example, one of my drives has folders named Drama, Factual and Films. Drama is not recognised by the Zidoo. (I have a Dune HD 4K Pro II that can see and access the folder no problem.) If I create a folder that will show before 'Drama' alphabetically, say a word starting with 'C' (I'll let you guess the folder name), the Drama folder appears, but the new folder doesn't.
I've had this problem on every firmware I've tried, including the latest. Is there anything I'm doing that would cause this, or do I need to report it to Zidoo?
DELUCAS
Can people Test Gapless playback think on the High End Models its enabled . 🙃🙃
edit confirmed on the Z9X. 👍
E2R
I upgraded from Z10 to Z10 Pro which is great as a media player from my Synology NAS using NFS.
My problem is with HDMI-IN which produces poor pictures as if the frame rate is wrong and loses the sound after a random period of recording every time.
Has anyone else suffered from this?
DELUCAS
Change logs:
System
1. Optimize the smoothness of Blu-ray playback in LAN.
2. Add DSD output mode selection for USB audio (D2P, DOP, Native).
3. Optimize EDID analysis in LLDV mode.
4. Fix the problem that Sony TV cannot wake up the device through CEC.
BlurayNavigation
1. Optimized the occasional crash when playing 3D movie.
2. Optimize the display of external subtitles.
3. Add a corner mark to indicate the type of movie.
4. Optimize the display of movie information.
5. Optimize PGS subtitle setting.
6. Fix the problem that some TVs cannot play 3D by default.
7. Optimize bookmark playback function.
Video Player
1. Optimize the display of external subtitles.
2. Add a corner mark to indicate the type of movie.
3. Added the function of adjusting the audio offset using the up and down keys on the remote control.
4. Optimize built-in text subtitle setting.
5. Optimize the seek function of video playback..
6. Fixed incorrect placement of left and right 3D subtitles.
HDMI IN
1. Optimize record function.
2. Optimize scheduled record function.
Home Theater
1. Optimize automatic scanning function.
2. Optimize the function of editing posters on the PC(added html5).
3. Added multiple video format icons in the detailed interface.
4. Fix the problem that the detail screen did not refresh after data update
5. Optimize search function.
6. Optimize interface display.
7. Fix the problem of devices offline occasionally
Music Player
1. Add USB audio setting.
2. Optimize favorite off all function.
3. Optimize the playlist function.
4. Optimize the acquisition of song name.
5. Optimize the page key to switch song.
6. HDMI audio supports up to 24bit output
Quick Setting
1. Add remote control up and down key multi-function setting.
2. Add USB audio DSD mode setting.
Z9X:
v6.1.03(Without Google play)
ttp://apidl.zidoo.tv/Z9X/v6.1.03/Z9X_P_v6.1.03_202102032049_ota-package.zip
MD5: 5015C8F72347A513612569E8CFE64F1F
v6.1.03_G(Build in Google play)
http://apidl.zidoo.tv/Z9X/v6.1.03/Z9X_P_v6.1.03_G_202102032110_ota-package.zip
MD5: 639A4BCA000B177914E5796CC12EBB47
Z9X:
Did say it would come ;)
DELUCAS
DELUCAS
DELUCAS
kiza
I have ripped a few DV disks and have ISOs on my NAS. I understand that file has to be converted to a different container in order to play DV movies. But not sure what to.
DELUCAS
There is a link on first page on MKV download if you have not used .
DELUCAS
DELUCAS
Change logs:
System
5. Fix >12TB hard disk that blocks the device(for UHD3000)
BlurayNavigation
Video Player
2. Add a corner mark to indicate the type of movie(Optimize position).
HDMI IN
Home Theater
Music Player
2. Optimize favorite of all function.
Quick Setting
Z9X
v6.1.05
http://apidl.zidoo.tv/Z9X/v6.1.05/Z9X_P_v6.1.05_202102041333_ota-package.zip
MD5: 2523B9D66D01179C313C57F274965D7C
v6.1.05_G(Build in Google play)
http://apidl.zidoo.tv/Z9X/v6.1.05/Z9X_P_v6.1.05_G_202102041348_ota-package.zip
MD5: BDD41227A43C7D51171F3CDBB2495423
Z10 PRO
v6.1.05
http://apidl.zidoo.tv/Z10_PRO/v6.1.05/Z10-Pro_P_v6.1.05_202102041418_ota-package.zip
MD5: 751A178605303AADF1511C7B619E4529
http://apidl.zidoo.tv/Z10_PRO/v6.1.05/Z10-Pro_P_v6.1.05_G_202102041445_ota-package_new.zip
MD5: 8413A553425B163DDF2CF60EF64E17FD
Z1000 Pro
v6.1.05
http://apidl.zidoo.tv/Z1000_PRO/v6.1.05/Z1000-Pro_P_v6.1.05_202102041811_ota-package.zip
MD5: 88E8B08C632B04853FDBFAFCF22567C6
http://apidl.zidoo.tv/Z1000_PRO/v6.1.05/Z1000-Pro_P_v6.1.05_G_202102041832_ota-package.zip
MD5: 38604BBBE8914D95153E7F52B2C1B7D2
UHD3000
v6.1.05
http://apidl.zidoo.tv/uhd3000/v6.1.05/UHD3000_P_v6.1.05_202102041717_ota-package.zip
MD5: 8F4A716F6B5875CA007737A859CD33FB
http://apidl.zidoo.tv/uhd3000/v6.1.05/UHD3000_P_v6.1.05_G_202102041735_ota-package.zip
MD5: 58B42E28BE3C6F353296FD821EE1D866
Podcast: Samsung TV Launch & QN95A Neo QLED Review, plus Film & TV news & Reviews
Latest News
Tidal streaming service acquired by Twitter/Square's Jack Dorsey
  • By Andy Bassett
  • Published
Netflix adds support for reduced theatrical release window
  • By Andy Bassett
  • Published
Paradigm launches Founder speaker series
  • By Andy Bassett
  • Published
AVForums Podcast: 3rd March 2021
  • By Phil Hinton
  • Published
Music revenue in U.S. sees vinyl sales overtake CD
  • By Andy Bassett
  • Published
