ZIDOO Z10 PRO - Z9X - Z1000 PRO - UHD 3000 Dolby Vision VS10 Owners Thread
DELUCAS
motorkiller
Both yes, maybe the next fw.
DLxP
Does anyone know, can the Zidoo player do vertical shift, like Kodi can? That is to say, can it for example shift 2.35.1 video down so that both black bars are at the top?
DELUCAS
Zidoo has its own version of Kodi called ZDMC and versions available 18.8 & 18.9 .
DLxP
Thanks. I thought that was the case. Do you know if ZDMC does vertical shift? In Kodi on my Shield I can do this - it's in the video settings when playing a movie.
DELUCAS
without checking id say yes but im out at moment
ZDMC is identical to Kodi but tweaked to run on Zidoo Media players .
DLxP
It would be great if it does. It's the difference between me buying a Zidoo to try and not buying one, as I find Kodi's vertical shift essential with my projector screen. If someone could check whether it does that would be great, as my internet searches aren't confirming anything.
Basically, Kodi on my Shield does everything I need apart from play 3D ISOs. So I'm wondering whether there's a player out there that can play 3D ISOs, but also has Kodi's vertical shift function.
DELUCAS
Minimise Black bars as in Stretch the video to the set up percentage in order to minimise Black bars?
DLxP
Not minimise the bars, no. I mean move the video so that the black bars are both on top. Kodi can do this. All you need to do on Kodi is go into the video settings while the video is playing, and choose 'vertical shift' - you can then move the active part of the video up or down.
I do this on my drop down projector screen so that the image is lower, with the bottom edge of the video at the bottom of the projector screen. Like so:
DELUCAS
Cant seem to find that setting on ZDMC / Kodi 18.8
all other settings yes .
can you show photo of that setting menu .
im leaning towards it does not have it or i cant find it .
DLxP
Yea, I'm thinking it probably doesn't then, as it's quite obvious in the settings. I've attached some pics. Basically, when watching a movie, pause it and go to the video settings, and it's there.
DELUCAS
Not getting that
what version kodi are you on ?
Small chance with Kodi 19 rc1 out Zidoo may release ZDMC 19rc1
it might come with it. ?
When was it added on kodi by the way .
DLxP
Not getting that
Small chance with Kodi 19 rc2 out Zidoo may release ZDMC 19rc2
I'm not sure when it was added to Kodi. I'm on v18.9. I've only recently discovered the feature. But now that I have, I can't live without it - it positions the video perfectly for my eye level and means the bottom border benefits from improved contrast against the black bar at the bottom of my screen. More players should have it, as it vastly improves the experience for anyone with a motorised projector screen.
It looks like I'll have to continue searching for something that does vertical shift and plays 3D ISOs. I'm not sure any player does that, so I may just keep the Shield for non-3D and get something cheap solely for 3D.
DELUCAS
is the Zidoo Z9X for 3D iso etc to expensive then ?
JBA6
@DLxP You can always install the regular version of Kodi on a Zidoo, you don't have to use Zidoo's ZDMC version, unless of course ZDMC does something essential that the regular Kodi does not. In case you wonder, as far as I'm aware, you can't have Kodi and ZDMC installed at the same time, it's one or the other.
JB
DELUCAS
One of the Reason Zidoo release there on version [ tweaked ] of Kodi [ ZDMC ] so it Runs properly on there platform .
Yes you can install Kodi on Zidoo but like previous Kodi‘s versions had issues on the Zidoo .
wether this has changed on the new chipset 1619 😎😎
DLxP
Not sure. Might go for one if it comes up in the classifieds, but it'd have to be fairly cheap if I'm only using it for a relatively small 3D ISO collection.
DELUCAS
Do you req Dolby Vision Vs10 side of things ?
if not can go the model before that if your after cheaper model.
inzaman
1. Fix the problem that some Dolby Vision videos are stuck (some MKV videos).
3. Add Dolby Vision compatibility mode.
With regards to number 3 update on .09 update does this mean you can switch DV off? I currently have auto for HDR section but my pj does not have DV.
Also for number 1 i was getting stuttering and other issues with LOTR UHD MKV file is this to help correct those type issues?
inzaman
Does your PJ have lens shift/memory as that is what i use to push my 2.35 images to the bottom of the screen?
saguk1234
I have lotr uhd and I get no stutter using WiFi. I am on .90 beta.
But sometimes my mkvs just freeze up.
DLxP
Yep, but I'm at the outer limit of that so it can't shift 2.35 right to the bottom (I'm using both vertical and horizontal shift, and using the latter limits how much one can shift vertically).
I prefer the Kodi approach anyway tbh; it avoids light spilling outside the screen from where the bottom bar would be (although I know that light is fairly dim anyway).
detroit1
I see this forum is much more up to date than the other one
Does anyone know if the x20 pro can handle 16TB, 18TB drives and if the WD 24TB Duo (2 x 12tb) will work with these units ?
Podcast: Samsung TV Launch & QN95A Neo QLED Review, plus Film & TV news & Reviews
Latest News
Tidal streaming service acquired by Twitter/Square's Jack Dorsey
  • By Andy Bassett
  • Published
Netflix adds support for reduced theatrical release window
  • By Andy Bassett
  • Published
Paradigm launches Founder speaker series
  • By Andy Bassett
  • Published
AVForums Podcast: 3rd March 2021
  • By Phil Hinton
  • Published
Music revenue in U.S. sees vinyl sales overtake CD
  • By Andy Bassett
  • Published
