ZIDOO Z10 PRO - Z9X - Z1000 PRO - UHD 3000 Dolby Vision VS10 Owners Thread
motorkiller
Hi Folks.
The new uhd 3000 support internal 2.5 sata ssd drive in the bays or only 3.5 hdd?
Sir QD oled
Hello,
Here is my humble experience with ht4.0
I do not use several devices because the zidoo does the job to enjoy my video library, so i have only a Z9X and my TV for Netflix, Disney+, etc....
I use ''thetvdb'' website to rename my TV shows before to scan them... i get 100% success for now...
I rename my movies with the tmdb website and I get 98% success.
If the name of your video files does not match with those of tmdb / tvdb, you will have a low percentage of success with the scan of your source.
And I do an export with HT4.0 to have the NFOs, poster and background in each movie folder
See you
Well that low percentage did frustrate me too so i installed the latest version of HT 4.0 you released on zidoo forum and was given to you by zidoo team. Results are immediately there, clear match with the Dune i got on 4400 files a rating of 98% and for movies the same. So problem resolved
if it is good i say it too;) thanks for the tip
DELUCAS
Expect a new Firmware for Models coming very soon for 2021 😊😊
DELUCAS
Hi Folks.
Will require a caddy Drive for ssd drives .
DELUCAS
Happy New Year to Everyone Firmware : v6.0.90
Change logs:
system
1. Fix the problem that some Dolby Vision videos are stuck (some MKV videos).
2. Fix that some TVs cannot output 3D by default.
3. Optimize online video streaming.
4. Optimize HDMI IN preview.
5. Fix the problem that the Blu-ray navigation cannot automatically frame rate switch.
6. Add Dolby Vision compatibility mode (this mode for the latest SONY 9000H firmware LLDV is abnormal, and some old LG TV HDMI IN models only support 2160P30 DV)..
player
1. Add UPNP video playback function.
2. Fix individual movies will be rustle of PCM audio.
3. Fix some videos cannot be played.
4. Fix the problem of audio slow output when paused.
5. Optimize bookmark playback function.
6. Optimize the subtitle download function.
7. Optimize the problem that the external srt subtitle will occasionally flash.
8. Fix output information display error problem on the information display interface.
Poster wall
1. Optimize NFO analysis.
2. Optimize part of the UI.
music player
1. Increase UPNP music playback function.
2. Optimize lyrics function.
3. Fix the problem that the song cannot be cut normally after playing from the file manager.
4. Optimize information acquisition in detail page.
File manager
1. Increase UPNP function.
2. Optimize NAS boot and mount speed.
3. Optimize UI.
Picture manager
1. Increase network picture page.
2. Add UPNP picture slideshow.
3. Fix the problem that the system music does not stop when slideshow.
Quick setting
1. Increase the compatibility mode switch of transparent transmission power amplifier (for some power amplifiers).
2. Increase the time setting of the bookmark function.
3. Add Dolby Vision compatibility mode.
4. Add resolution lock function.
Mobile APP (scan the QR code of the machine to download and update)
1. Fix the problem that the music search page cannot play music.
2. File manager adds UPNP function.
3. Optimize the cue music playback function.
4. Optimize music favourite function.
5. Added music play-list mode.
6. Optimize some UI.
Z9X:
v6.0.90(Without Google play)
http://apidl.zidoo.tv/Z9X/v6.0.90/Z9X_P_v6.0.90_202012311835_ota-package.zip
MD5: 20B87A79C5F46626C450B7F7371F0439
v6.0.90_G(Build in Google play)
http://apidl.zidoo.tv/Z9X/v6.0.90/Z9X_P_v6.0.90_G_202012311849_ota-package.zip
MD5: DB3F350CA1001B1EB62DF02E5D4818E2
Z10 Pro:
http://apidl.zidoo.tv/Z10_PRO/v6.0.90/Z10-Pro_P_v6.0.90_202012311756_ota-package.zip
MD5: 9BCC4311FF818BD27C14E3F3D2C3ACB2
http://apidl.zidoo.tv/Z10_PRO/v6.0.90/Z10-Pro_P_v6.0.90_G_202012311810_ota-package.zip
MD5: C3D9D028D6F92B1E49CECBD56C091ECB
Z1000 Pro:
v6.0.66(Without Google play)
http://apidl.zidoo.tv/Z1000_PRO/v6.0.90/Z1000-Pro_P_v6.0.90_202012311707_ota-package.zip
MD5: 433F983521D9FCF04E9224954808379E
http://apidl.zidoo.tv/Z1000_PRO/v6.0.90/Z1000-Pro_P_v6.0.90_G_202012311723_ota-package.zip
MD5: 92F96C617370D71A848C90D84B5FC31F
UHD3000:
http://apidl.zidoo.tv/uhd3000/v6.0.90/UHD3000_P_v6.0.90_202012311612_ota-package.zip
MD5: C25559805AD181A6D72331774EB73AAD
http://apidl.zidoo.tv/uhd3000/v6.0.90/UHD3000_P_v6.0.90_G_202012311638_ota-package.zip
MD5: 1EBCD1E225686CA4A20C985DE7A0B172
Happy new year!!!
How to activate Google Play Store:
1. Open Play Store, then close it - this generates the GSF ID
2. Goto Settings/Other/About and take a note of the GSF ID
3. In a web browser, goto www.google.com/android/uncertified, log in and enter GSF ID and hit <Register>
4. Restart ZIDOO device.
DELUCAS
Hi Just updating the firmware with google play services.
lets see what the changes are like.
Regards
KeithW
Should be in the step in the right Direction .85 was positive so a few more fixes added to the firmware .
will update soon my laptop Power supply has failed :(
DELUCAS
Updated all fine but a first to update just using the Z10Pro and wi fi to download & install firmware .
sodesfeux
changelog 0.85
Changelog 0.90
DELUCAS
Firmware : v6.0.90
Z9X:
Z10 Pro:
Z1000 Pro:
UHD3000:
Happy new year!!!
eegah
Thanks Delucas,
Great that they have fixed the missing audio after a pause, it was becoming infuriating.
Happy New Year to you too.
DELUCAS
ZIDOO Controller APP :
motorkiller
Hi.
Hdmi 1 video output not pass trough audio when connected the hdmi2 other device?(UHD3000)
Thank you
DELUCAS
Hi.
Thank you
Bit confused if you can connect UHD3000 Direct to your Receiver then hdmi out to your screen .
or Hdmi out port Video Signal to screen and Hdmi Audio port to your Amp / Receiver if you have a reason to do so .
motorkiller
The reason is i've got jvc exofield headphone for the late night. My plan was hdmi1 connected to the processor(main system) and hdmi 2 to the jvc . Ordered one hdmi splitter i hope so solve this problem.
Thank you.
Ptenisnet
Thank you.
Would love to know your impression of the uhd3000 as I’m thinking of going for it or the Z1000 Pro
DELUCAS
Thank you.
They are an Expensive pair of headphones !
can you not connect Zidoo hdmi audio out to your processor and Zidoo hdmi ( main ) output to screen / Receiver etc
so video / Audio to Receiver and when you want headphones working just change settings in Zidoo for Headphone usage ( audio output )
( if Zidoo UHD3000 has that setting option )
Not had one to test so im hoping settings has that option .
motorkiller
I'm not find this setting options. I have oppo players there possible switch in the menu, here looks like automatic switching.
Anyway, not a big deal arrive the splitter and problem will be solved.
DELUCAS
Yes oppo has
so like your self id imagine it would have .
Maybe that option may come in a firmware update ?
motorkiller
Hi.
Hard question because i used only one night. Picture quality looks better, but i d'ont have any measurement tools.
HDR new options looks like little bit bugy with the new fw. Netfix didn't work, i can't log in my premium acc in to the youtube, only if i downloaded from the google play but that one not working well with the remote control etc.... Software problems :D
motorkiller
Yes oppo has
Fingerscross :D
DELUCAS
DELUCAS
Make sure hdcp is set 2.2 in settings
DELUCAS
Is the movie scrapper better on the z9x than the z9s?
The scraper or H.T.v4 can be updated to one of the latest ones on its own apk
some are having issues with it but as ive said before if you name the Movies & tv series it correctly you will have more success rate .
Podcast: Samsung HW-Q800A Soundbar & Rotel Michi X3 Reviews + TV show and Movie News & Reviews
Latest News
Trinnov Audio announces Crestron Home driver
  • By Andy Bassett
  • Published
Rotel announces upgrades to 14 and 15 Series amplifiers
  • By Andy Bassett
  • Published
What's new on UK streaming services for May 2021
  • By Andy Bassett
  • Published
Samsung's 110-inch Micro LED TV on pre-order at Harrods
  • By Andy Bassett
  • Published
Bang & Olufsen introduces Beosound Emerge speaker
  • By Andy Bassett
  • Published
