hodg100
Outstanding Member
- Joined
- Aug 8, 2005
- Messages
- 14,220
- Reaction score
- 4,522
- Points
- 6,489
I'm watching at 24P on my Android box as I speak so not sure why you say that?
edit - just googling now, looks like I've made a mistake and it's xbmc running on android OS that's the problem...at least it appears like this? I assumed this was a problem with android setups and not xbmc, although still not sure?
Can you tell me what android boxes can do all frame rates then? I have read on here that 24p is a problem so you get stuttering, also they are unable to change rates automatically and require manually changing depending what your playing
I can't speak for others but my Minix X8H seems to do well, automatic switches to 24P as necessary. I have 2 options for frame rate switching, either in XBMC/Kodi or there is a system wide option for auto switching, which in theory should work with other apps as well, I mainly use XBMC so couldn't comment on other apps.
Hi I am new to this comment box , I have just purchased my 1st android box I have the Zidoo X9 and think it's a great little box exactly what I was looking for the only few issues I have and wonder if anyone can help is, (1). I have installed the BBC iPlayer app from the Google play store but it won't play anything properly it's really bad and I don't know what else to try ??
Hi Mark its John again are you free to help out on something I am slowly getting to grips with this thing but just have a problem with the a tv guide ??
