ZIDOO X20 / X20 PRO Super Audio DAC Owners Thread
mtenga
Garry123
Has anybody managed to get their music collection to be recognised by their Zidoo, without it being in a mess?
Any help would be appreciated.
JBA6
Sorry Garry, Not possible using the Zidoo Music 3 app. A shame as version 2 showed promise and recognised the tags of most songs and albums reliably, something that seems quite beyond Music 3. As mentioned above I use Kodi for music playback instead which apart from resampling to 48KHz, works perfectly. I don't find the resampling spoils the sound quality which is still excellent on my system.
JB
Garry123
JB
Just tinkering with zdmc. just need to find which version is best and see if i can get aeon mq working.
edit: got aeon mq working with 17.6.
JBA6
Garry,
Thanks for the reminder about Aeon MQ. I hadn't tried it for a while because as far as I can see it doesn't show the progress of a playing song and it doesn't show an album's total duration both of which you get with Confluence. Aeon MQ8 works perfectly with Kodi 18.2 on Windows and sure has some great graphics. I'll try it on Android later but I don't see why it wouldn't work with Kodi or ZDMC 18.2. I don't have a Zidoo any more but I'll try it on my current Android box and report back.
JB
Garry123
Garry,
JB
I got aeon mq working. Had to install it usin the apk.
JBA6
Aeon MQ8 added to Kodi 18.2 running on my current Android 8.1 box.
Aeon MQ8 is certainly a very impressive skin with loads of customisation possible. It's probably going to take me a while to get it set up to my liking but good to see that if when it's playing any music track and it's in full-screen mode then the track's total and elapsed times are displayed.
JB
Garry123
What settings do people use for their display parameters? Not completely convinced on the picture quality.
Sir QD oled
Model: Zidoo_X20_Pro
Version: v2.2.96
Download: http://apidl.zidoo.tv/X20_PRO/v2.2.96/ZIDOO_X20-Pro_N_v2.2.96_201909251127_ota-package.zip
MD5 Hash: BEF984AB67F7CFB1CDE75367110B0535
Upgrade method:OTA
Changelog:
System:
1.Fix the occasional green screen problem of HDMI IN
2.Optimize optical RAW output.
3. Optimize the stability of system.
4. Add German and Polish language support.
5. Fix the occasional noise problem when playing video.
6. Fix the problem that some online video applications couldn't be played.
7. Color depth output 10bit by default.
8. Optimize application stability.
9. Optimize online playback.
10. Fix the problem that the front panel USB icon was not displayed.
11. Optimize seamless branching issue.
12. Fix occasional prompts "the format is not supported" when playing dts music via HIFI MUSIC APP.
Music Player
1. Solve occasional error message of playing the music through the file manager.
2. Lyrics closing function is added.
3. Add German and Polish language support.
4. Optimize stability of application.
5. Optimize the function of obtaining music information.
6. Optimize the problem of automatically switching the next track.
7. Fix the stuck problem of 64bit music players.
8. Optimize the music basic information interface.
9. Add album folder recognition function.
10. Solve the abnormal songs display problem in flac album folder.
11. Optimize the image recognition and profile text recognition of album folders.ú¿need to clean the old data and rescanú⌐
12. Fix the problem that some CUE songs are not successfully matched.
13. Optimize recognition error caused by suffix identifier of the folder.
14. Add scroll bar for list.
Control center
1. Add the function of uploading screen shots from mobile phone.
2. Optimize stability of connection .
3. QR code for downloading IOS and Android app.
Poster wall
1. Solve crash issue during the matching process.
2. Solve the problem of recognizing ISO music as ISO video.
3. Improve the recognition rate of files with parentheses in file names.
2. Fix the abnormal focus problem in the APK file management user interface.
4. Compatible with title of file name with "íñ".
5. Optimize local image recognition.
6. Fix inaccurate automatic update due to the incorrect judgment of the video file.
7. Solve the problem that the restore function of mobile phone control app does not work.
8. Add function to view folder directly in device list.
9. Add device synchronization function.
10. Solve jitter issue caused by long device name when scanning device.
11. Solve abnormal folder size display on folder viewing interface.
12. Solve losing focus problem after stop scanning in the device list interface.
13. Fix the issue that BD cannot be deleted.
14. Solve the problem that non-Chinese and non-English titles could not be matched.
15. Fix the problem that the poster modification from web page cannot select image on the computer.
16. Category browsing by movies/TV series.
17. Optimize accented characters incorrect sort issue.
18. Optimize the initialization speed of the sorting tool.
19. Solve the occasional crash problem on category browsing.
20. Turn on background dynamically by default.
Local player
1. Add Blu-ray forced subtitle.
2. Press the delete button on remote control to delete plug-in subtitle.
3. Add more information interface for app control.
4. Optimize the progress bar.
5. Optimize play button no response problem after popping up menus.
6. When switching to 3D mode, associated frame rate will pause time.
7. Fix the problem that bit rate 1b/s show up coincidentally.
8. Optimize some shortcut keys.
9. Fix the problem that the download subtitle from mobile phone is different form media player.
10. Add Playlist on Mobile phone App.
11. Add more information of video display on Mobile phone app.
Quick settings
1. Add function that forced subtitles follow the language of audio track.
2. Fix the problem of incomplete German display.
One-click cleaning
1. Add Polish language support.
How to upgrade
If you have installed google play kit, please reinstall it after upgrade.
New ZDMC 18.3 http://apidl.zidoo.tv/app/zdmc-18.3_rtk-signed.apk
New Gapps 1.2.4 http://apidl.zidoo.tv/app/GappsInstaller-rtk-7.1_v1.2.4.apk
Sir QD oled
for the X20
Model: Zidoo_X20
Version: v2.2.96
Download: http://apidl.zidoo.tv/X20/v2.2.96/ZIDOO_X20_N_v2.2.96_201909251202_ota-package.zip
MD5 Hash: 8B9DAD8869E19F0E903AC1C500CAAE90
Upgrade method:OTA
Changelog:
System:
Music Player
Control center
Poster wall
Local player
Quick settings
One-click cleaning
How to upgrade
THX2002
Hi all, old thread so hoping people still view from time to time.
I don't know if it is coincidental, but ever since I upgraded to the latest firmware the poster wall no longer shows any artwork, both cover and background. You can go to change the image, find the cover, then click save, and for a split second it looks like its trying to save it, then you are left with nothing, just the standard movie wheel icon.
Really scratching my head as to why it cant save covers.
DELUCAS
Go on my Z10 thread and there is a link to update H.T.v2 to latest one .
THX2002
Thanks for the suggestion.
Is the file hosted anywhere else? I cant use mega, it says i have used up my quota.
THX2002
Actually, just found a newer version;
So will give that a go and report!
DELUCAS
Latest News
LG UltraGear Gaming Monitors get VESA certification
  • By Ian Collen
  • Published
Sony confirms UK pricing for A90K and A75K Bravia XR 4K OLED TVs
  • By Ian Collen
  • Published
LG announces new CineBeam HU915QE 4K laser projector
  • By Ian Collen
  • Published
Movies Podcast | Maverick IMAX Review, 4K Disc News and More
  • By Phil Hinton
  • Published
