dazm41
sorry my bad will go over to correct thread to many model numbersHe has the Z10 Model .
There is another thread for the Z10 model etc
and use diff firmware and are very slightly diff spec wise as such .
Any ideas of the changes please delucas?
Do you have a new link?Tested and working it seems H.T. v3.0.10 on my spare X10
so a little lease of life for these tried and trusted older models .![]()
Any major changes delucas?
Any idea when the new HT3 comes out?If you have already got the trailer updates it dont seem a huge update to H.T.v2 etc
but it has added a few more tweaks under the bonnet more refined and turn off options that many wanted and still being updated as we speak .
H.T.v3 .... just gets better and better
time its released it look great to the Z series front end .
at least they are listening to some peoples issues .
major changes yes for the ones that are still on H.T.v2 without trailers update etc .
In my own opinion.
Poss June with New Firmware release
But id imagine the Z Series will be released first then the X Series etc
HTv3 is virtually finished in testing and adding options .
just a nice polish off of it .
Note they are starting to loose a little support for the X series as in firmware but so far they still are .![]()
It was a surprise to see when I opened my 10 today! I was automatically updated!
short question: i have my X10 connected to an Denon Atmos Receiver. I have a few Atmos MKV but the receiver only shows TrueHD. Apple TV is also connected and it shows Atmos. Any idea?Result Enjoy![]()
thanks, will try later...just which HDR Setting do you mean? Receiver setting should be ok, because Apple TV Atmos is working.Only suggestion is the Zidoo likes or needs a Quality 4K Certified 4K Hdmi lead and can drop out Atmos sound because of this .
make sure your on latest Firmware .
power down your box and mains out etc .
make sure Receiver settings are correct that the Zidoo is connected to for atmos etc .
Zidoo is set to Raw and last check thing poss Change the HDR settings
as that caused me a loss of sound on my set up .
Which player are using, Home Theatre 2 or Kodi?short question: i have my X10 connected to an Denon Atmos Receiver. I have a few Atmos MKV but the receiver only shows TrueHD. Apple TV is also connected and it shows Atmos. Any idea?
HT2Which player are using, Home Theatre 2 or Kodi?
No OTA updates as yet on my X10.Update : check your box H.T.v 3.0.40 should have been pushed through with OTA update .
Dont know if its come to the Xseries ?
can someone confirm if so .
i found the apk download from this side. Works perfectly for now.No OTA updates as yet on my X10.
Still on H.T. v2.1.36
