Zen/MediaSource help needed
Discussion in 'Headphones, Earphones & Portable Music' started by Pecker, Dec 29, 2004.
  1. Pecker
    Pecker
    Dec 26, 2004
    22,381
    Huddersfield, People's Republic of Yorkshire
    +4,495
    Right, I've put the software on my PC. I'm now ready to transfer tracks from my PC to my Zen.
    According to the instructions, I've got to click the 'Destination Transfer' button.
    What is it? Where is it? What does it look like?
    I've tried mousing over everything I can see, and nothing comes up as 'Destination Transfer'.
    Steve W
  2. Pecker
    Pecker
    Dec 26, 2004
    22,381
    +4,495
    Of course, once I'd figured out I could just 'drag & drop', it all became blindingly easy.
    Sorry for the daft question!
    Steve W
  3. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    if you want to use creatives software which i think is is very good, to transfer music using this all you do is connect your zen to the pc using the usb cable, then fire up media source, if you notic far down on the bottom right hand side of the screen there are 2 arrows if you move your mouse over it it says (show/hide right panel) click on it so it shows the right pannel, then all you do is the click mouse over the top right hand side where it says pc library, it should give you an option to select your zen as destination, you then over at the left hand side select you pc as your source. To transfer music all you do is zelect a folder on the left hand side click on it then click on the right arrow on the middle of the screen to transfer music to the zen
