Zappiti tv series question
Discussion in 'Video Streaming Boxes & Services' started by liamthefirst, Feb 18, 2014.
  1. liamthefirst
    liamthefirst
    Aug 27, 2012
    1,484
    Eastbourne
    +357
    hi
    my setup:
    server with WHS2011, MyMovies to rip and my movies store Movies but i use zappiti to store tv shows.
    the problem is untill now i have never tried to rip my tv series bd colection. the way zappiti wants tv shows stored is.... Heroes--Season 1- S01E01. well when ripping using my movies it makes just one iso file? i don't really want to install Make mkv to separate episodes. so is there an anything i can do with just one iso file with say 3/4 episodes?
    thanks
  2. graham.myers
    graham.myers
    Mar 11, 2003
    6,228
    Leeds
    +931
    The problem with My Movies is it cant jump to a specific m2ts file for a particular episode like it can with tv series on DVD. You will have to use something other than my movies to rip to mkv for each episode.
  3. liamthefirst
    liamthefirst
    Aug 27, 2012
    1,484
    Eastbourne
    +357
    Ok thanks Graham.
    Would you say makeMKV is best program for the job?
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,547
    Rainham Essex
    +2,523
    It is what I use, its free and easy to use - what's not to like :)
    For Zappiti just stick the TV series in a folder named the same as the show. You can have separate subfolders per season if you want but they are not required. I then just name each episode as S01E01.mkv etc and Zappiti then scrapes them from that - you can put more into the file name, but it is not required.
    Mark.
