Quantcast
Zappiti showing movie thumbnails more than once
pandarin
I am using Zappiti Version 2.1.2735.100 on my Dune Smart H1. Everything worked pretty well for a few months, but a couple of days ago I added some more movies and after that Zappiti is showing the same thumbnails two or three times when viewed from the Dune. When viewed from my computer, Zappiti is perfect.
Did anyone have a similar problem? How did you solve it?
Thanks for your help.
Pandarin
MarkE19
I would suggest you try deleting the _Zappiti & Zappiti_Resources folders in your Export Path location. If you then rerun the Export to Dune it should recreate them - hopefully with just the one copy of each cover.
Mark.
