Zalman cooling - any alternative ?
Discussion in 'Desktop & Laptop Computers Forum' started by smallangryboy, Jun 21, 2004.
  1. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    I'm looking at cooling a P4 3Ghz [or higher] processor. I have been recommended the Zalman Super Flower Cooler [copper] but it comes with a huge warning that you have to remove it when moving your PC.
    OK I understand most PC's live in one place all their lives, but having something in your PC that may damage it if moved is a bit daft. How delicate is it ? I mean can I move it from room to room without damaging anything or is it worth using an alternative ?
    I need an efficient but super quiet fan for my P4 which will live in the STRATA 390 PC case - anyone have any ideas ?
  2. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    Upstate New York. USA
    +27
    I did look at the Zalman cooler, but there were issues fitting it to the Abit AN7 mobo and it would be too near the PSU, so I've gone for a Samurai from QuietPC. It's just arrived so I haven't had a chance to fit it yet.
  3. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    wyred
    With the Samurai cooler am I right in thinking it has an external speed control, which takes up a slot at the back of the PC ? Do you have to fit this or can you leave it off and control it via other means [e.g. software]
  4. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    Yes, it does have external speed control which does tape up a slot. It looks like that that's the only way to control it - no s/w.
  5. The Dude
    The Dude
    May 21, 2004
    6,265
    Beverley, East Yorkshire
    +2,588
    you don't have to mount the controller permanently in a pci slot.. only if you want to be changing the fan speed..
    I just left mine in a slot until i'd worked out the maximum silent speed with the case closed ( which is virtually full power ;) ) , then made a mark on the knob and removed the controller again..
    the controller is now taped to one of the cross-members inside my case, so no Pci slot used..
  6. Ciaran500
    Ciaran500
    The reason you have to take that cooler off the board when moving it is the weight. It will pull either the clips off the CPU slot or pull the whole lot off the mobo.
  7. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    So best bet is to use the Zalman Copper/Alu hybrid version then I guess
  8. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    You should be able to move the PC with the zalman in place as long as you are careful : no sudden movements especially if the board is mounted vertically . Done it plenty of times myself with no ill effects.
  9. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    Admittedly the all copper version of the zalman is a bit of a beast (about 700g as I remember!), but whether this will be an issue in real life I'm not so sure. I don't think you'd need to worry about moving it from room to room occasionally, it just seems that if it's slung about the weight of the heatsink might produce a bit too much force on the retention clips. In a strata 390 it's not installed horizontally as it would be in a tower, this seems to be a safer way TBH, the main force is directed down into the MB rather than parallel to it.
    I'd be interested to hear if any one has actually had any problems associated with the weight of this product or whether its just a cautious note as it exceeds the standard spec for this kind of product.
    Just my thoughts,
    Owain
  10. Donnacha
    Donnacha
    Jul 4, 2002
    8,029
    York
    +4,150
    The Samurai is very, very quiet, and easy to fit. I had a spare slot at the back to put the fan controller which I use a bit, 'cause my loft can get very warm and if I'm doing any encoding, then I need to whack up the speed to keep the CPU cool.
    At low speed you can't even hear it!!
  11. The Dude
    The Dude
    May 21, 2004
    6,265
    +2,588
    have you got any stats for your samurai Donnacha?
    I've got the kamakaze and i'm interested in the differences..
    I'm running an XP2800 in a soundproofed case, running the Kamakaze at 1750rpm keeps the cpu below 52deg whatever i throw at it..
    ( though I do have 2 80mm vantecs which are handily positioned inline with the heatsink, could well be assisting to some extent)
    how does the samurai compare ?
  12. Yandros
    Yandros
    Oct 13, 2003
    2,714
    +528
    I've built 3 PCs with the Zalman 7000A Al/Cu, and also bought a custom PC with one (and had it shipped with the heatsink in place). The mounting looks solid enough to me. The solid copper version apparently doesn't offer much improvement in cooling, so I've never bothered with that, considering that it's overweight for the socket. I'd say the unless you are in the habit of chucking your PC around , I really wouldn't worry about the weight of the Al/Cu version at all.
