Z3 question, really simple
Discussion in 'Projectors, Screens & Video Processors' started by blasted, Jan 24, 2008.
  1. blasted
    blasted
    May 26, 2004
    1,189
    63
    +132
    I am getting a Z3 and i would like to know which is the best way to connect my computer to the projector for watching films. It has both a s-video plug and a 15 pin vga plug. My graphics card will output either DVI or s-video. it will be for watching hd material of the hard drive.
    Blasted
  2. spooney
    spooney
    Oct 2, 2006
    2,252
    Seyring
    +204
    S-Video will only carry standard resolution therefore you need to go for the DVI-VGA.
    Please note DVI - HDMI although technical possible with the proper cable will not process any purchased material with a higher than standard resolution unless you card supports HDCP. Not applicable with the Z3 of course.
  3. blasted
    blasted
    May 26, 2004
    1,189
    63
    +132
    Thanks for that, it hadent even occured to me that i might need hdcp. I have an x1800xt and im not sure if it has it, i shall have to dig out the box.
    thanks again.
