Z3, Powerbook and Widescreen resolutions
Discussion in 'Projectors, Screens & Video Processors' started by Roamerick, Nov 19, 2004.
  1. Roamerick
    Roamerick
    Hi all,
    First post here. I just got my Sanyo Plv-Z3 - which I bought after finding good reviews of it on this very forum - and I'm having a bit of a problem with getting my Powerbook G4 (running OSX 10.3.4) to detect the projector's native Widescreen (1280x720) resolution.
    The projector comes up as a VGA Display, with only 4:3 ratios available. Now, the connection to the powerbook is currently RGB, and under the manual of the Z3 I saw that the widescreen resolutions should be available under a HDMI connection. Is there no way of getting them under the RGB connection as well?
    An Epson projector I was using before was detected fine, so why is the Z3 being difficult? Still, the projector is amazing. The image quality is staggering!
    Thanks in advance for your help :)
