Z3 Focus. ?
Discussion in 'Projectors, Screens & Video Processors' started by grahambateman, Nov 19, 2004.
  1. grahambateman
    grahambateman
    Hi.
    You will have read that i have raved since the purchase of the Z3 unit. However over the last 2 days i have noticed a deterioration in the picture . For some reason , i cant get the picture sharp , its really deteriorated . Anyone got any idease her please.
    Graham :lease:
  2. stevelup
    stevelup
    Aug 13, 2002
    6,516
    Swindon
    +1,090
    Are the menus sharp?
    If they are, then it is likely you have a source / cable fault.
    If you can't bring the menus into sharp focus then there must be something mechanically wrong with the optical path.
    Steve
  3. lpr
    lpr
    Are you using lens shift? If so you could try to move it and reposition it to its original position. I've noticed that lens shift (if not in the sweet spot) could cause some focus shift in the frame (i.e. corners not in focus, but center is). Maybe yours has moved a bit.
    Hope this help.
    lpr
