nightofjoy
Established Member
Hi.
I just got a Sony Z3 Compact and I'm trying to set it up... having a few issues.
Firstly, it seems to have every sound, light and buzz activated, like everything is flashing and tweeping and humming.... on my old Android phone, apart from switching off alerts in each individual app, there was also an Applications Manager where you could switch off alerts. I can't find it on my new phone, is it still on there or has Android abandoned it?
Also, I'm trying to add a desktop wallpaper image that I had on my old phone. The pixel size must be larger than the Z3 screen size, but rather than opening the whole image then saving it to the right size, it's just opening a portion of the pic... roughly a third, the amount that will fit to screen. I can slide it around to view the off screen areas, but I don't seem to be able to do a fit to screen crop. Any ideas?
Finally, the drag down bar at the top which gives glimpses of incoming messages and texts, can I disable it, or at least control which apps post to it?
Thanks.
Thanks.
