Z3 ceiling mount
Discussion in 'Projectors, Screens & Video Processors' started by Bogeyed, Dec 10, 2004.
  1. Bogeyed
    Bogeyed
    Nov 12, 2004
    79
    Holmfirth,West Yorkshire
    Can anyone recommend a good ceiling mount with say a 30cm extension for my new Z3 ? Also what size mounting bolts to use for the three tapped holes on the underside of the pj? I assume it is still better to align the pj with as little lens shift as possible even though this is quite generous on this machine.
  2. zAndy1
    zAndy1
    Nov 26, 2002
    19,596
    2
    5
    163
    +6,696
    There's only one site you need... www.lmp-pc.co.uk their mounts are fantastic!
    Andy
  3. Bogeyed
    Bogeyed
    Nov 12, 2004
    79
    zAndy1 -OK thanks for that ,I'll look them up. By the way have you had any problems mounting the Z3 upside down?
  4. Comer
    Comer
    Sep 21, 2001
    1,365
    Ireland
    +82
    I haven't heard of anyone having problems mounting the Z3 upside down :smoke:
