Z3 Ceiling Mount Questions
Discussion in 'Projectors, Screens & Video Processors' started by 1ofaKind, Mar 16, 2005.
  1. 1ofaKind
    1ofaKind
    Dec 16, 2002
    233
    Midlands
    +4
    Hi All,
    Just wondering what ceiling mounts people are using for a Sanyo Z3.
    I assume that I have to remove the front flap off the PJ as I guess it will be upside down as the holes are on the bottom?
    Also if anyone has ceiling mounting is it okay cleaing with the air puffer while its upside down or will I need to remove it?
    Sorry if the questions are incredibly stupid :eek:
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,180
    UK.
    +2,721
  3. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    I have a Z2 and used Garys site as a reference to make a ceiling mount.
    You can see a picture of it here
    It works fine, the front flap stays on as the little feet give enough distance between the bottom of the projector and the wood for the mount.
    The only thing that i missed is the filter opening, but it has been cleaned before i put it up so should last many months yet well hopefully until i get another projector :D .
    The mount however works perfectly well and is a good option as opposed to buying one for £150 or whatever they are imo.
