Z3 cable
Discussion in 'Projectors, Screens & Video Processors' started by Kahless725, Nov 18, 2004.
  1. Kahless725
    Kahless725
    I have a Z3 and a sky box, I want to take the sky's rgb scart and put it in to the z3's vga/rgb port. Do I need to buy a special sanyo thing or does anyone know where to get a cable that does this, only needs to be 1.5 to 2m long.
    Cheers in advance
    Robert.
  2. triumphtiger
    triumphtiger
  3. stevelup
    stevelup
    Aug 13, 2002
    6,405
    Swindon
    +1,035
    Yes, the Keene one works fine. I'd avoid the Sanyo one as it's twice the price and of much poorer construction quality.
    Steve
  4. Kahless725
    Kahless725
    Cheers, much appreciated.
  5. linnite
    linnite
    Nov 10, 2004
    699
    28
    Burscough, Lancs
    +48
  6. Kahless725
    Kahless725
    Ordered Thusday late so hopefully should get it on Mon Tues?
  7. Plastictree
    Plastictree
    Nov 14, 2004
    4
    I live in Italy and bought the Sanyo cable (POA-CA-SCART) 'cos I wanted to connect the SKYBOX and the new Z3. Unfortunately it doesn't work: the image is visible but distorted... The projector with the same cable works fine with a DVD player and the decoder, also, works fine connected to a TV with a cheap SCART cable (RGB enabled on both) :confused:
    Do you think the Keene's cable can be different from what is produced by the projector's firm?
    It seems the problem's coming from the the very low quality SKYBOX... it is a Thomson with two SCART (one with RBG-OUT)
