Z3 and HDMI input
Discussion in 'Projectors, Screens & Video Processors' started by morph42, Nov 18, 2004.
  1. morph42
    morph42
    Nov 17, 2004
    15
    3
    Hello all - apologies for asking a question on my first post.
    I have had a Z3 for a few days now and so far have been blown away by the picture quality from a component feed. Today I have tried to connect my PC to the projector using a 3m DVI to HDMI lead from Maplin. The clarity of my PC desktop on the projector screen is very good - the only hitch is that about 5-10% of the screen on all 4 sides is out of view - it appears that the image has some overscan on it. I have an ATI 9800pro card and use the latest 4.11 catalyst drivers and the resolution is running at 1280-720 to match the projector.
    I have tried to mess around with powerstrip settings with no avail.
    I have also plugged my PC into a friends Z2 using his DVI-DVI cable and it works perfectly.
    Is the problem something to do with the Z3 or possibly the cable I am using?
    Thanks in advance
  2. zAndy1
    zAndy1
    Nov 26, 2002
    19,603
    2
    5
    163
    +6,701
    You can adjust the overscan on the Z3 in the advanced menu.. check the manual it's in there somewhere. I think the default is 10% overscan but you can reduce that down to 0% if you want
    Andy
  3. Kahless725
    Kahless725
    I noticed that overscan was set to 10 on mine as well by default. When I get the Samsung DVD player which uses a Farathing scaler to scale to 720p do I need to set overscan to 0 in a similar way as you need to with PC's?
  4. morph42
    morph42
    Nov 17, 2004
    15
    3
    Well, that was an easy fix - I hadn't seen that menu before.
    Thanks for the help. I hope you're enjoying your Z3 as much as I am enjoying mine
