Z3 and a hint of green!
Discussion in 'Projectors, Screens & Video Processors' started by EnglishJohn, May 20, 2005.
  1. EnglishJohn
    EnglishJohn
    May 1, 2001
    248
    Suffolk
    +6
    Sanyo Z3 colour uniformity
    Hi can anyone help, I have a slight tint of green on the left side of my screen (you only notice it very slightly in certain scenes) I don’t want to have to send the unit back just yet as its not exactly life threatening.
    Is there any adjustment, maybe in the service menu to help tweak it out?
    Cheers guys.
    John
  2. EnglishJohn
    EnglishJohn
    May 1, 2001
    248
    Suffolk
    +6
    Has anyone got any ideas on removing this tint?
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,079
    UK.
    +2,571
    This is probably a colour uniformity issue that LCDs can suffer from, and I don't think you can fix it. Try calling Sanyo customer support and see if they will fix it/replace it for you under warranty.
    Gary.
  4. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,762
    Babel Sensurround
    +207
    Try turning the iris down to -21
    Adrenochrome.
  5. sainthalo
    sainthalo
    Feb 24, 2005
    630
    19
    is it just like 1 pixel all the way down? i have a yellowy green 1 pixel width sometimes across the bottom and right but i assume it is the source file i am playing. i did send it to sanyo for firmware upgrade and colour uniformity but the engineer said he found nothing wrong with the image and could not see any green. if you read sanyos site they mention this problem but i do think its related to source material as well.
  6. Geesus
    Geesus
    Dec 23, 2003
    2,223
    116
    +696
    I have a *slight* tint of green in the bottom left corner and blue in the bottom right, but it is very, very feint and does not impact at all on moving images...indeed I only see it on pure black scenes.
    I have a few small faults with my Z3, but I'm just going to get on with enjoying the positives as otherwise Im likely to lose even more of my hair :D
  7. EnglishJohn
    EnglishJohn
    May 1, 2001
    248
    Suffolk
    +6
    cheers guys for the feedback, as Geesus has said i think i will try and live with it - not abig deal and i might end up with somthing worse - nobody else has noticed it.
    Rango snayo they said to contact supplier... might leave it for now its gotta 3 year warrenty anyway.
    Im glad its not just me with a minnor niggles.
  8. Geesus
    Geesus
    Dec 23, 2003
    2,223
    116
    +696
    I think we have to remember that although these are expensive pieces of kit, we are still talking 'budget' model projectors, so I guess the prospect of perfection is unlikely to be met.
    Still loving my Z3, and that dead pixel seems to be fading (I wish!) ;)
  9. sainthalo
    sainthalo
    Feb 24, 2005
    630
    19
    very happy with mine too especially playing super monkey ball deluxe on xbox with component cables. also girlfriend is very happy too :)
