z2,xbox,component = 1 word,WOW
Discussion in 'Projectors, Screens & Video Processors' started by gibbajabba, Jan 6, 2004.
  1. gibbajabba
    gibbajabba
    Nov 24, 2003
    70
    I just got one of the xbox component leads online for like £9 delivered,hooked it up to my z2,slapped in a disc which converts my box to ntsc mode,whacked up 480p,720p on the xbox,threw in need for speed underground and i was blown away! I had allready read from you guys that its good so i did have high hopes and i wasnt dissapointed,cant believe how good it is!
    Thanks to all for providing the info that made me try this :clap:
    Ive fiddled with the settings manually on the z2 to see what its running on as the pj is set to auto and its running on 480p on the two games ive tried,can the 780p be much better than this!
    Now ive gotta see if i can get films to play on proggressive,anyone with a z2 and an xbox has gotta get it modded,this should be made the law :laugh:
  2. cyberheater
    cyberheater
    Apr 3, 2003
    3,186
    Scotland
    +170
    Have you tried DVDx2 software for Xbox with the progressive scan patch. It's awesome...
  3. gibbajabba
    gibbajabba
    Nov 24, 2003
    70
    Ive not heard of it but im gonna have a look around on google :cool:
  4. fama
    fama
    Jan 28, 2002
    142
    .whats this disc ? to enable component ntsc
  5. cyberheater
    cyberheater
    Apr 3, 2003
    3,186
    Scotland
    +170
    It's the enigma vid mode switch disc. You need a modded xbox and download the software which is built using a leaked version of the Xbox sdk so it's a bit dodgy. Well worth it though.
  6. gibbajabba
    gibbajabba
    Nov 24, 2003
    70
    Just been playing,amped 2,disneys skate adventure and true crime all in 720p.The quality and smoothness is unreal,words just cannot describe! :D :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
    Could a 10 grand pj really offer much more than this?
  7. sanj
    sanj
    Oct 24, 2002
    128
    Newport
    +6
    Hi all,
    I'm really keen to try this out on my Z2 but does it stop you using your XBOX for Live?
    I have a UK XBOX, a Joytech advanced cable kit and was wondering should I bin the cable and get a different one, such as the monster advanced cable?
    Thanks in advance,
    Sanj
  8. gibbajabba
    gibbajabba
    Nov 24, 2003
    70
    First you need to get your console modified,you should be able to find a local computer shop that does em.Check before they do it that a switch will be installed to disable the chip.Most modern chips have an led on the front off the box thats on when the chip is enabled.Now you can disable the chip and use xbox live with no problems,but you wont be able to go on xbox live with a backup game or they will still ban you.Heres the lead you will need http://www.whitedog.co.uk/catalog/product_info.php?products_id=288
  9. sanj
    sanj
    Oct 24, 2002
    128
    Newport
    +6
    gibbajabba,
    thanks for the info, I'll order the cable tommorrow.
  10. paulw77
    paulw77
    Nov 18, 2000
    477
    Wigan
    +17
    But that lead only does stereo, not 5.1.
  11. sanj
    sanj
    Oct 24, 2002
    128
    Newport
    +6
    True, paulw77 I've looked into it a bit more and to get 5.1 one
    of the options seems to be a combination of two monster cables, one for the component and the other a fibre optic to go to the processor. Both of these ain't cheap, so I'll do a bit more research first.
  12. TheBoyGUK
    TheBoyGUK
    Nov 23, 2001
    93
