Z2, what does this setting mean?
Discussion in 'Projectors, Screens & Video Processors' started by dekoded, Feb 2, 2005.
  1. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    Me again, I have now got a 10mtr component cable and have my Z2 connected to my pioneer dv565 dvd-player.
    Whilst twiddling with the settings I found very little difference between outputting pal interlaced component or ntsc progressive component (can't do pal prog) so have decided to stick with pal inter.
    After messing with the menu options I somehow managed to lock myself out of the menu, the left hand side of the box appeared but the main box wouldn't!
    Do I need to reset my pj?
    Also after reading the user guide (p29) I found the 'progressive' setting and it says
    "interlace video signal can be converted to a progressive signal
    off...not activated
    L1...for active picture
    L2...for a still picture"
    What does this mean :confused: , how can it be off when a pj has to display a prog image? is it just a badly written manual? and if not which option should I use with my pal inter component signal?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I can't recall this setting in my old Z2, but from your description it seems to disable the deinterlacer in the projector. You'd want to do this if your are feeding progressive from a player, I assume the Z2 doesn't auto-detect this and thus needs you to tell it using this option perhaps.
