B
bergsey
Apologies if this question has been answered elsewhere.
I'm looking for the best way to connect the Z2 to a PC.
The distance is around 7 - 10 m
Currently my PC only has a VGA card but looking to future proof.
Should i go for
(a) DVI-I to DVI-I cable, and purchase a seperate DVI-I -> VGA adaptor
(b) DVI-I to VGA cable
(c) DVI-D to DVI-D (does Z2 accept this ??)
I've read elsewhere that there are possible problems with this length of cable. Are there any (inexpensive) alternatives ??. As the Z2 is ceiling mounted I can't really shorten the length.
Should i go for
