Z2 Startup screen
Discussion in 'Projectors, Screens & Video Processors' started by MacReady, Mar 28, 2005.
  1. MacReady
    MacReady
    Jun 25, 2003
    2,453
    3
    Barnsley, South Yorkshire
    +192
    Has anyone changed the startup screen on their Sanyo Z2 ?
    I fancy changing it to a different picture which, according to the manual I can do, but am not sure how to do this as my pc is not connected to the projector.
    Do I just need to save an image to a CDR as a Jpeg and then save the image as the startup screen?
  2. MacReady
    MacReady
    Jun 25, 2003
    2,453
    3
    +192
    I have pretty much sorted this now. Just dumped and image onto a CDR as a bitmap and then projected it and stored it as the new user picture...only problem is that it is the wrong size.
    Saved it as a 1368x768 screen after seeing something about this over on the AVS forum but that dosn't fill the screen...does anyone know what resolution to save the image as so that it appears correctly:confused:
