z2 quick question..
Discussion in 'Projectors, Screens & Video Processors' started by iforgot, Dec 10, 2003.
  1. iforgot
    iforgot
    Been reading the forum here for a while, post manly over on nextgen's or n3.co.uk's
    Have recently bought a sanyo z2, (from ivojo) and have a quick question ...
    Is it possible to get the z2 to show how many hours have been used? and if so how?
    Since ive now reg'd here ill post more here now.
    If anyone knows the answer either way...thanks :D
  2. Anders_UK
    Anders_UK
    There should be a section in the menu that shows lamp life...not sure to the menu structure as i don't own one but all the other PJ's I use have it and I would be very disapointed if it didn't.
    Keep checking..its there somewhere
  3. iforgot
    iforgot
    there is a counter reset and a lamp mode but no way that i can see of displaying hours useage !!
  4. kbfern
    kbfern
    Aug 17, 2002
    17,217
    Wolverhampton
    +5,294
    I have a Z1 and if you press and hold down the up key on the projector case (for about 20 seconds) your used hours will show on screen.
  5. kbfern
    kbfern
    Aug 17, 2002
    17,217
    Wolverhampton
    +5,294
    That should read up arrow key
  6. iforgot
    iforgot
    tried that and the other directions too...no luck there.
    One assumes that there must be a way ???
  7. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    apparently you hold the power button on the remote for 30 seconds.....
    ad
  8. iforgot
    iforgot
    yer the power key on remote for 30 seconds is the one:DP:D
