Z2 Projector Problem - possibly Bulb
Discussion in 'LCD & LED LCD TVs Forum' started by jomppa, Mar 17, 2005.
Tags:
  1. jomppa
    jomppa
    Sep 24, 2003
    Pontypool, Wales
    My Z2 stopped suddenly exactly after I had watched a movie the other night. The red Lamp Replace DOES NOT come on. :(
    The Z2 appears to be just about to start (green light on) and fan is on then it turns itself off. I have read somewhere that this maybe the lamp - even if the Lamp Replace DOES NOT come on ...
    I haven't had it serviced since I bought it December 2003.
    Does anyone know a cheap place (even outside the UK) which sells Z2 bulbs as I am thinking of buying one to see if that helps.
    J :)
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    I think you have posted in the wrong forum...Try the next one down, "
    DLP & LCD projectors". I guess the topic of this forum would be better described as "LCD TVs & displays" so I can see the confusion.
    -Ian
