Z2 problem
Discussion in 'Projectors, Screens & Video Processors' started by gibinho, Aug 28, 2004.
  1. gibinho
    gibinho
    Firstly I'd just like to say the problem isnt screen door:). Ive had the pj since release and its just appeared the last couple of weeks
    I had a similar issue with my Z1 just before I replaced it with the Z2. The easiest way to describe it it is now like looking at the picture through a net curtain. Its especially noticable on videogames where there is transparency effects. It makes it look like the graphics have went back 10 years and things like smoke consist of alternating pixels. Does it ring a bell with anyone?
  2. gibinho
    gibinho
    Ive had a closer look and thought on how to describe the problem better.
    What may be the issue is that Ive noticed that (maybe) in my efforts to reduce VB Ive introduced horizontal lines. Anyone know what setting may have done this?
