Z2 mounting poll
Discussion in 'Projectors, Screens & Video Processors' started by The Hemulen, Dec 8, 2003.
  1. LMP mount (<100mm)
    2 vote(s)
    10.0%
  2. LMP mount (100-200mm)
    6 vote(s)
    30.0%
  3. LMP mount (>200mm)
    2 vote(s)
    10.0%
  4. Custom/DIY mount
    3 vote(s)
    15.0%
  5. Wall mounted shelf etc
    3 vote(s)
    15.0%
  6. Coffee table etc
    4 vote(s)
    20.0%
  1. The Hemulen
    The Hemulen
    Dec 5, 2002
    512
    Cambridge, UK
    +9
    Just curious how people are mounting all those new Z2's out there..
  2. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    I have mine slung under a wall mounted shelf with my DVD player above on the top side of the shelf. :smashin:
  3. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    I haven't fully decided how to mount mine yet.
    If I go the LMP route, it won't be until next year sometime when I can afford it.
    The DIY route is tempting, but I have this nagging feeling that I'll mess it up somehow...
  4. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    I voted Custom/DIY as I customised a portable TV stand myself :D (turned it upside down :smashin: )
    [​IMG]
  5. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    10cm mount.
    For those still umming and arring go for keystone correction bits, even though the 2 has lens shift, I wish I had. WIthout it if the mount is perfectly level the projector will require keystone correction. You can get round it by using washers in addition to the spacers. Better all round to have the mount do the correction for you
  6. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +10
    I'm still worried about mounting mine as I don't have a clue where the ceiling joists are! Anyone know how I can find them without making too many holes? Are there any sucessfull and cheap 'sonar' type sensors or anything?
  7. The Hemulen
    The Hemulen
    Dec 5, 2002
    512
    Cambridge, UK
    +9
  8. homethx
    homethx
    Feb 24, 2002
    728
    +78
    Just got a lmp mount on order 20cm with twin keystone adjustment do you think it's to long though ?
  9. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    I was lucky enough to get the free LMP mount so it is on my ceiling waiting for the final installation on thursday! :D
    ad
  10. UZUBAIRU
    UZUBAIRU
    Jul 6, 2001
    557
    Manchester
    +23
    I've ordered the 20cm with twin keystone adjustment.
    It's arriving on Wednesday.
    I couldn't be sure that the celings in my house are level.
    Umu
  11. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Good choice, they wont be :)
