Z2 Focus and Lense shift
Discussion in 'Projectors, Screens & Video Processors' started by BestGear, Jan 28, 2005.
  1. BestGear
    BestGear
    Oct 22, 2003
    1,263
    +48
    Hi Folks
    Anyone found any issues with focus linearity when using lense shift on the Z2?
    Having relocated my Zed It looks like the focus is not consistant (top to bottom) in my case when using lense shift much past the central position.
    D
  2. Gilbers
    Gilbers
    Nov 17, 2004
    742
    43
    +157
    Yes, I've experienced this problem. The only solution I found was to close down the iris to increase the depth of field. This will also cut down the light output of the PJ, so it's not ideal, but it does work.
