Z2 firmware 1.09
Discussion in 'Projectors, Screens & Video Processors' started by trinemus, Nov 2, 2004.
  1. trinemus
    trinemus
    I just upgraded my Z2 from firmware 1.06 to 1.09 but where can I see what have chance from one version to another one? I have an 1910 player and It looks like both itmes have problems with 720p 50 Hz. Can anyone mail me the new firmware 1.10 to my Denon 1910 for pal region 2?
  2. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    How did you upgrade the firmware on your Z2 ?
  3. trinemus
    trinemus
    In a shop where they sell projectors. It cost about 100 $.
  4. eatstatic
    eatstatic
    Oct 22, 2002
    1,136
    Centre of the Universe
    +45
    This is getting a little frustrating, everytime I contact Sanyo I am told that there is no firmware upgrade for the Z2.
    However (My z2 Ver 1.03) I actually have version 1.06 on disc but I am reluctant to flash the unit myself as I do not want to risk loosing warrenty.
    Has anyone had any luck in up-dating in the UK?
    eatstatic.
  5. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    What do these firmware upgrades actually relate to ?
  6. trinemus
    trinemus
    The newest version is 1.09, but I dont want to upgrade my self, because if somthing is going wrong it is very bad. Sent it to a shop then you get the newest version, and then you can get them to clean the lcd panel also if you have problems with dust bobbels, I have.
    :thumbsup:
  7. trinemus
    trinemus
    It is correction error like problems with DVI connection and other stuf.
  8. eatstatic
    eatstatic
    Oct 22, 2002
    1,136
    +45
    trinemus,
    Believe me when I say I have tried. I have contacted Sanyo myself to be told there is no such thing as a firmware upgrade, I have contacted the Sanyo service centres to be not told as much .... but they would charge £150 to clean the machine but that they would be no upgrade done..yeah thanks.
    Wish things worked as like they seem to do in Denmark, and everywhere else except the UK.
    paulw77,
    The improvements I was after helped with vertical banding but also below is taken from a french site (google translation) in answer to your question
    firmware for PLVZ2 v1.06 which corrects since the 1.01 defects of colorimetry, compatibility HDCP, the correction of some bugs (safeguard of the adjustments of gamma and zoom modes not deforming.
    eatstatic.
  9. trinemus
    trinemus
    Regarding Vertical Banding can I say I have non, and before the upgrade to 1.09 it was so bad that I was sad very time I saw a movie, but now It is very good also i blue there is non. This is not to rub your nose.
  10. bommaren
    bommaren
    Just to inform you that there are problems still
    with [email protected] with the 1.09 revision firmware.
    I have not succedeed in always getting a syncronised picture
    when useing [email protected] and component connection.
    I have read that DVI-D still have problems.
    - B
  11. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    What source are you using ?
  12. bommaren
    bommaren
    I am using a XCard from sigma designs.
    I have created "mode lines" to generate what i belive is the correctly
    timed [email protected] Hz signal.
    I have gotten it to accept the signal if i start the projector with
    this signal active, so i belive the timing is correct.
    But I cannot get the Z2 to resync to this resolution if I switch
    from any other resolution.
    - B
  13. irishstu
    irishstu
    I upgraded the firmware on the z2 last night from 101 to 106
    easy!
    I plan to start a new thread with instructions how when I get a minute
  14. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    That would be great !
  15. BestGear
    BestGear
    Oct 22, 2003
    1,265
    +49
    ...the instructions and flash utility is already out there.... just go look....
  16. xavk1
    xavk1
    Aug 9, 2004
    590
    28
    +36
    Guys,
    I have foudn the instructions and have the 1.06 firmware file already. My issue is that I dont have the necessary cable, and dont fancy making one. Can anyone advise where I could obtain one (either buy or borrow)?
    Xav
  17. WheeIbarrow
    WheeIbarrow
    Jan 24, 2017
    Sweden
    This is a a long dead thread, but gonna make a try for it. Did anyone ever manage to update the firmware, and where did you find it?
    I see that both xavk1 and eatstatic had managed to come by the firmware somehow and are still active users so I cross my fingers you got an answer 12 years later. This is more to close the chapter on that old projector so I can move on.
  18. eatstatic
    eatstatic
    Oct 22, 2002
    1,136
    +45
    Yeah did not expect to see this pop up! Your going to be relying on my memory.
    I never updated the unit, I ended up upgrading & sold the unit.
    From recollection I obtained the firmware from the supplier although can not be 100% sure.
    Its a long shot but I sold the unit to a friend (who may still have it). I can ask if you wish.
    What are you wanting close out?
    All the best
