Jimbobgod
I imagine there are quite a few people on here using a Z2 in conjunction with the LMP ceiling mount. Having used the pj fairly intensively over the last few months, I thought I'd try and clean the air filter...only to find that the mount plate means you can't get the filter out without taking the pj off the mount completely...unless someone else has worked out how to do this?? Seems like a poor piece of design on the part of the mount I think, all it'd have taken would've been a cut-away section of the plate above the filter access
Jimbob.
Jimbob.
